pacrat wrote:
Hmmm. Sounds like you maybe wound up with a 6mm AI or Ackley Improved chamber. Did the extra .100 increase the shoulder angle? Is shoulder/body juncture larger diameter than factory? Or was chamber just cut to deep?
Indications are, the chamber is just too deep. I attribute that to the barrel not being seated, but maybe I don't know what I'm talking about. I've machined all my life, but I am not a gunsmith, nor do I pretend to be one. Shoulder angle appears to be identical, just a greater distance to the head.
Quote:
Even an AI chamber is cut to headspace at neck/shoulder juncture and safely fireform factory ammo rather than datum point so should not cause split cases.
The second round that didn't split permitted me to discover why the other two had split. It also permitted me to reset my resizing die for making new brass, which worked without issue. It was clearly longer than the rounds that were fed to the rifle.
Quote:
Got any pics. You've quite peaked my curiosity bone.
Don't have any, but it may not be impossible. While the rifle is in storage, I may be able to locate some of the loaded ammo, maybe even a fired case or two. It's been so many years since I messed with my guns that it's hard to remember anything about them at this point. Assuming I can locate the loaded rounds, would that be something you'd like to see? Define your request and I'll see if I can answer the questions.
Quote:
Quite the dilema.
Only because the barrel was engraved as a 6MM. It could prove interesting if the rifle fell in to hands that weren't aware of the anomaly.
It is truly a wildcat cartridge, although I suspect without any benefits.
