plugging a barrel for bluing ....
Moderators: Harold_V, JackF, GeorgeGaskill
Butch
What is "Vapor Hone"
Post by Butch » Fri Jan 31, 2003 12:56 am
Never heard of that.
gunner312
Re: plugging a barrel for bluing ....
Post by gunner312 » Sat Feb 01, 2003 12:39 am
What you plan to do is properly called "Rust Bluing" or "Belgian Bluing" For a proper methodology to accomplish this, take a look at John Traister's book, "Professional Care and Finishing of Gun Metal". THis was the book we used in class as a reference in Gunsmithing School. (Rogue Community College, Class of 87) In it it tells the proper methods to use to prepare the metal for bluing and each step of the way. The method was originally developed to use on shotgun barrels with soft-soldered ribs because of the tendency of the Hot Tank method to un-solder the barrels. It does give a pretty finish and is very durable. My (almost) only problem with it is that it takes so darn long to do. Personally I'd rather just put it in the tank and have it done in 15 minutes. un-soldering is seldom a problem with modern barrels because of the solder used to put the barrels together isn't a lead-based solder. In any case, it is not necessary to plug the bore in any method of bluing that I am familiar with and with some it is darn right dangerous to do so.
Just clean the bor at each step.
epanzella
Post by epanzella » Mon Dec 24, 2018 4:45 pm
I use only rust bluing. Plug the ends with dowels, coat the barrel with solution, let rust for 2 hours, boil in distilled water, card off. Repeat as necessary. I always do it 4 times but the 4th time is usually unnecessary as it gets fully dark after 3. I just like insurance. Change the water after every boiling. Rust bluing is awesome as any surface that was capable of rusting is already rusted so the gun is virtually impervious to water. PS; I never had a plug pop out as you only bring the barrel up to 212 degrees.
Ed P
SAVE A COW, EAT A DEER
earlgo
Post by earlgo » Thu Jan 10, 2019 1:56 pm
epanzella, I may get in touch with you if you don't mind. I am re-learning to rust blue for a friend who has an old Marlin and doesn't want it "DuLited" ie commercial black.
gunner312, if you are still around, I'd like to thank you on recommending the John Traister's book, "Professional Care and Finishing of Gun Metal". I found a copy on amazon. It was published after I graduated from the Colo. School of Trades so I did not know it existed. Really great reference book and better than Angier's "Firearm Blueing and Browning".
--earlgo
epanzella
Post by epanzella » Sun Jan 13, 2019 4:34 pm
--earlgo
Sure, no problem.
Ed P
Ed P
