Barrel Liner Drills ????
Moderators: JackF, Harold_V
rbertalotto
Post by rbertalotto »
I just picked up a Winchester 1873 carbine in 44-40 caliber with a "sewer pipe" bore.
I have a 44-40 barrel liner from Brownells
I already have a 38-40 deep barrel drill bit.
The OD of both the 38-40 and 44-40 liners are the same.....
But the pilots on the drill bit are different
.38-40 - .391" (9.9mm); .44-40 - .419" (10.6mm).
What do you think about grinding the tip of the 38-40 drill and adding a bushing to guide it in the bore of the 44-40 barrel?
This is what the "pilot" looks like on the drill bit:
http://www.brownells.com/userdocs/produ ... 4000_1.jpg
I hate to buy another $103.00 drill bit as I'm not sure I'll ever bore another 44-40.
Any comments are greatly appreciated.
hammermill
Re: Barrel Liner Drills ????
Post by hammermill »
In the past I have silver soldered on a extension
hammermill wrote:In the past I have silver soldered on a extension
That's not what he needs. What he needs is a sleeve that would permit the small ground portion to pilot in the larger bore. Soldering, in this case, would not be a good idea.
There's no reason why one can't be made and used. It would perform best if it was hardened, honed, then ground, but I expect that one made from prehardened material (4140) would perform adequately, at least for one use.
hammermill
how true I was on the wrong end. Of things.
PeteH
Post by PeteH »
Kind of a tangential question.
I was looking at the .22RF liners, and I see that one of them costs more than 2x what the others do. OK, it's 7" longer, but that oughtn't justify THAT much of a premium. Anybody here got a suggestion about that price differential ?
BTW - I tried to post a question to Brownells website but kept getting a "profanity filter" popup; and there was no questionable language in my post.
Pete in NJ
redneckalbertan
Post by redneckalbertan »
Do you have links to the two liners? Could be different material, made to different tolerances, different method of rifling. I have no clue I'm just spit balling.
PeteH
Post by PeteH »
Nothing in the "details" or "Q&A" that I could find. Here's the page with the three variations:
http://www.brownells.com/gunsmith-tools ... 10974.aspx
Bewildering. I note there are no reviews for the expensive one, and several for the cheaper. That might tell the tale.
Pete in NJ
redneckalbertan
Check back in a few days or so, the site let me ask a question, so I asked what the differences are between the two liners.
hammermill
Want to bet it's a 17 cal barrel mislabeled??
rbertalotto
I decided to rebarrel the rifle with a Green Mountain barrel back to 38-40. which is what it shipped from the factory as.
You can read all about it on my web site
www.rvbprecision.com
Thanks for all the previous help!
