cutting new slot in weaver mount
Moderators: Harold_V, JackF, GeorgeGaskill
jpitz31
Post by jpitz31 » Tue May 05, 2015 2:29 pm
Hey all
Newbie here,
I have a Hatsan air gun, The welded weaver mount is missing a slot closest to the rear of the receiver
I would like to mill an extra slot. The process appears to be rather straight forward.
I have never mounted a barrel into a vice before, Air Gun barrels have the air chamber and receiver
behind the barrel.
Would a v-block be the best way to mount the receiver or would there be a better way to do so.
Thanks
Joe
GeorgeGaskill
Re: cutting new slot in weaver mount
Post by GeorgeGaskill » Wed May 06, 2015 3:03 pm
If you could provide a close up image of the piece in question, we could give a better answer. But normally, one holds round stock in the vise with one V-block from the side, the vise compressing the stock between the fixed jaw and the V-block. Non-round portions of the stock can complicate holding it. Also, some method of aligning the piece so the cut is made as desired is needed.
jpitz31
Post by jpitz31 » Wed May 06, 2015 5:42 pm
Thanks GeorgeGaskill, I will an image and post it.
Joe
