32-20 barrel
32-20 barrel
All the gunsmiths must be on vacation, haven't seen anything on the board for awhile. I'm looking for a 12 inch barrel that would be good for a 32-20, .311 or .312. I have a 303 barrel but it isn't big enough on the OD ( need .875) . I thought I had one in my pile of stuf but it turned out to be a 32-40 barrel. May have to break down and buy a new one [img]/ubb/images/graemlins/frown.gif"%20alt="[/img].
Re: 32-20 barrel
Numerich/Gun Parts had some good deals on some .308 barrels awhile back.
I would use a .308" barrel and chamber ...
with a 3° leade. It would take .308" bullets and .311-.312" bullets safely and accurately.
Re: 32-20 barrel
Would be even better if it had a complete action attached to it!!
Al Messer
"One nation, under God"
Re: 32-20 barrel
Redman makes a 32-20 barrel liner page 36 Brownells #54. Maybe you can drill out the 32-40 and use that.
Re: 32-20 barrel
Found a 32-20 barrel for $60 including shipping ( Les Bauska). Found out my chamber reamer won't work on the 303 barrel, bore to small. If I were going to use a liner I wouldn't use one from Brownells, the OD is metric. I get my liners from TJ's. The reason for not using a liner is the costomer doesn't want a liner. Thanks for all the ideas
