I'm scoping out what it would take to make a rifled 12-gauge barrel. The first step is the basic barrel. It needs to be .729 ID and smooth.
I'd like to avoid rifle drilling bar stock if at all possible. I may be able to acquire some thickwall 4140 seamless tube (see note), but the closest match of OD and wall thickness has a nominal ID of .625. I'd need to open up the ID by .104".
Vickery and Howe talk about roughing reamers, but they apparently cut .004 to .020", depending on the bore. It's usual to have a 3-reamer set - roughing, finishing, and burnishing, though you can burnish by other methods.
The reamers look pretty simple; there are fully dimensioned drawings in the books.
So, should I make half a dozen roughing reamers to step up to the finish reamer size, or is there a better way to do it? I was thinking about something like a piloted spade drill, perhaps.
(note) not all sizes in the steel catalogs actually exist; they're just "standard" sizes if you order enough from the mill to meet their minimum quantity.
opening up a tube
Re: opening up a tube
get dom tubing 1" od x.729 id it will work on 12 ga barrels
