The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Sat May 25, 2013 2:27 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Sun Mar 11, 2012 1:51 am
Offline
Got a sketch?
Top
 Profile
PostPosted: Thu May 10, 2012 10:13 pm
Offline
I took a dead center MT3 that fits my tail stock and used an adapter to put it into my head stock. I first ground the point flat about 1/2" across, I faced it flat, then bore a hole .010 OD of the reamer end to a depth of .125. I use the dead center as a pusher along with a short reamer wrench, so if the reamer catches or chatters I can let go and the handle does not hit any part of the lathe and reamer is free to spin with the barrel. Also when I'm at the desire depth or want to clean the reamer, I just let the handle go and pull the reamer out after the lathe stops. That way there is less chance of a chip scoring the chamber. Also you have more feel in what the reamer is doing. To begin reaming you oil your reamer and chamber, insert it into the chamber just short of cutting, bring up the tail stock and push center to just make contact with the reamer. With your right hand hold the reamer wrench pulling back into dead center in the tail stock(lock tail to ways), start the lathe, switch hands while keeping back pressure, then advance the reamer to cut by the tail stock spindle. I hope I made this clear enough. The hole you bored in the dead center should have enough clearance so the reamer can move if it needs too. Effective and simple ,I guess you could call this method a floating reamer????
Top
 Profile
PostPosted: Fri May 11, 2012 10:25 am
Offline
At the risk of looking really studid, oops to late, :P , I have to ask:
How does a floating reamer holder get the reamer started on center? If I understand the princiapal of using a floating reamer it is to allow it to bore straight into the chamber and not cant at an angle as one might expect if they were not perfectly aligned for up/down and front/back with the tail stock.
Dave C.
_________________
I learn something new every day! Problems is I forget two.
Top
 Profile
PostPosted: Sat May 12, 2012 2:05 am
Offline
Dave C.
The key word in your post is allow, if you have a true bore and it is dialed in dead nuts, the floating holder and the proper bushing on the reamer allows it to stay straight.
James
Top
 Profile
PostPosted: Sat Jun 02, 2012 9:13 am
Offline
Dave C.
James
Well, not so much. Dave's question is very spot on, and is proper. In my view, a floating reamer holder is a recipe for chatter and an over size chamber. There are so many opinions on this, but I'll explain mine.
A floater is "supposed" to correct misalignments in a setup. To do that, it must move axially to "follow" a bore. So Dave's question about how can it start off right if it isn't aligned, is valid. A reamer with a pilot bushing has clearances. There is clearance between the bushing and the reamer, it has clearance between the bushing and the bore/lands. While these aren't big clearances, take that short 1/2" long bushing with the clearances inside and out, and place it in the end of a barrel, only as deep as the bushing. Now go to the end of the reamer and see how much wiggle there is. There is always wiggle, you can't have zero wiggle. So again, how is a floater supposed to align this?
The floater goes against every fundamental principal in metal working, which is RIGIDITY! Would you attempt to turn a piece of stock down with your QCTP loose? I doubt it. So why send a reamer in to do the job when it is loose? One problem some smiths have when chambering is chatter. Chatter comes from different things, but most can be related to something loose somewhere. A loose fit between the pilot and the bore is a big problem, which is why a reamer with a bushing pilot is used by the top guys.
One of the top and respected riflesmiths in the Country is Mike Bryant, he has a website. He made a uses what he calls a "pusher". Not really a floater, but it's just a hollow collar that the reamer end fits into, and he pushes the reamer with the "pusher" held in a chuck in the tailstock. It allows some room for movement with the reamer. However, there is more to the story. He does what most BR quality smiths do I believe, which is drill out most of the chamber, reach in and indicate in the bore/grooves, single point bore this drilled hole true. This way, the reamer has a trued hole to follow which is aligned, and the bushing isn't guiding the whole reamer. Plus, he uses a DEAD CENTER in the tailstock to start the reamer and uses it for over half the chamber, then switches to the pusher.
So why switch to the pusher at all? Well, a couple reasons. Once the chamber is established, the reamer will continue to follow, and there is much less chance for problems. There is also the issue of whether the tailstock feed will continue on the aligned path while being extended.
Why do some many people take so many pains to align and indicate in a barrel where they never see a needle move, and never do a thing to get the tailstock aligned as well? That is the first thing I do when setting up my lathe. You have to level the lathe properly, then go through the process of aligning the tailstock with the headstock. This is both fore and aft, and up and down. The check how the tailstock quill travels from in to out. Does it go up or down, or front to back, or run true?
You get your tailstock aligned, and you can use a dead center to drive the reamer, and have a well aligned chamber, a rigid setup, and much less chance of chatter problems. Plus, you can leave the barrel turning while you pull the tailstock back to clean chips from the reamer, where you cannot do this with a floater. Another no-no the floater people do, is use a one sided/handle holder on the reamer. This induces an off center loading on the reamer, and with the floater that can and will move, another chance for an over size chamber. Use a holder that is double handle, equal length on both sides of center, push with a dead center, and you'll be happy with the results.
My opinions here, everyone needs to do what their machine and abilities allow for the end result.
Top
 Profile
PostPosted: Sun Jun 03, 2012 1:32 pm
Offline
Wayne,
Thank you very much for the time it took to write out those details! Very good explanation and I got a pretty good picture of what is going on here.
Dave C.
_________________
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
