making a mount to attach on a pic rail
gwhunter21
Post by gwhunter21 » Mon Aug 26, 2013 10:48 am
hi all I am new here and new to machining, I know absolutely nothing I bought a smithy 3 in 1 and now I want to make a mount for my go pro to attach to a pic rail. My question is what bit do I need to mill the part that attaches to the rail? would it be a double 45 or is there another way. I have tried calling the local supplier and he has no idea as to what I want and when I went there he was not there, If someone can tell me the proper name of the bit I need I would be grateful
gwhunter
JackF
Re: making a mount to attach on a pic rail
Post by JackF » Mon Aug 26, 2013 10:54 am
I'm going to guess you need a dovetail cutter. Go to the MSC web site and google "dovetail cutter". You should find what you need. :D
Jack.
P.S. We love to know the location of our members, noobees especially, there are times when a nearby member can lend assistance.
Post by GlennW » Mon Aug 26, 2013 2:57 pm
Possibly a "Double Angle Shank Type" cutter.
http://www.use-enco.com/cgi/INPDFF?PMPA ... PG=INLMK32
GeorgeGaskill
Post by GeorgeGaskill » Mon Aug 26, 2013 4:38 pm
I use a double 45 to make the ones I have made but the cutters are usually too thick and I end up with clearance above the rail. It hasn't caused any problems but I don't get a close fit there. I suppose I could grind off the top of the cutter for more clearance.
gwhunter21
Post by gwhunter21 » Thu Aug 29, 2013 11:16 am
thanks guys i just order a double 45 I appreciate all the responses
mclarenross
Post by mclarenross » Wed Sep 11, 2013 1:00 am
With some creative fixturing you can make a female picatinny mount using just a regular endmill. The internal angles are 90* so just set the work at 45* and you have your internal angle.
Lance Corporal of Marines
