Making a chamber reamer
Moderators: JackF, Harold_V
homebrew .357
Post by homebrew .357 »
Hi all, Hope the xmas and new year hang over has just about gone, but those guys at CNN need to check things! Auckland in Australia?? :oops: .
Ok, just got in to making my first chamber reamer, c a l 45-70-.450" on my lathe. It`s made of silver steel, like drill steel I think and just looking at the best way to harden it, oil or water quench?. This is for a barrel I have just drilled to .430" ID, is it best to rifle first or chamber first.? This is for a Sharps 45-70-.450" bore, yer I know sharps 45`s are all .456/8 bore, but this is the size my gun drill and reaming I can get to, . Cheers, Homebrew.357.
Six sided reamer cutter
Re: Making a chamber reamer
The heat treat isn't something you choose---it's determined by the type of material you selected. Some are oil hardening, some are water hardening and some are air hardening. If in doubt, avoid water, as it may shatter the wrong material.
When you plunge the heated reamer, make sure it goes straight in from the end. If you quench from the side, pretty good chance you'll end up with a warped reamer.
hammermill
Post by hammermill »
i am guessing you a a d style reamer ?? and yes the type of metal determines the hardening process as advised by harrold. if using oil wear gloves and have a cover ready in case flame becomes a issue
love to see pics of your efforts
homebrew .357
Hi, This is a six cutter reamer, as I used my rifling register to index and just shaved the flutes with the top slide and then cut the relief . I`m sure you are right, Silver steel needs to be heat treated in oil and tempered to straw.
Wish I could win lotto so I can buy a Mill :roll: ,this is going to be a long build, I have the plans for the Sharps Quigley 45-70-110 ,may have to buy in some parts. :wink: ,afew more pic`s ,Homebrew.357.
cutting the cutter
cutting the cutter
Rifling register for six flutes
hammermill
8) congrats that is a interesting approach and a inspiration on getting things done by utilizing the tools you got :D
homebrew .357
Hi, And thanks for your reply Harold and Hammermill and just to make sure I`M on the right track there`s reamers have a relief cut close up to the sharp cutting edge , how close to the edge , I`M at ( 0.034" ) back from it, is this ok or a bit more. :?:
The barrel will have to be rifled before I ream it and looking at a twist of 1-20 /24, just need a 5 1/2" DIA small bike sprocket for my rifling gear head, it will turn faster for the quicker twist.
Hope you guy`s are keeping warm over there, :( here the sun is shining, 8) great, Cheers, Homebrew.357.
homebrew .357 wrote:just to make sure I`M on the right track there`s reamers have a relief cut close up to the sharp cutting edge , how close to the edge , I`M at ( 0.034" ) back from it, is this ok or a bit more. :?:
There's two schools of thought in reamers. One of them, chucking reamers, the periphery of the reamer is circular ground (like yours right now) with a narrow land. The land is intended to guide the reamer, which cuts on the end only.
The second school of thought is a reamer that's intended to cut on the sides (like a hand reamer). Such a reamer must have almost no land, so the flute can cut on the periphery. The greater the land size, the tougher it's going to be to get the reamer to cut. Typically, such a reamer is ground with a primary and secondary relief, with the primary relief creating a sharp edge at the front (the flute). This relief will appear to you as being a land, but it is not. The grind provides for a modest amount of relief, so the reamer makes contact ONLY at the cutting edge. Such a reamer will cut with the least amount of effort.
So then, to produce a reamer that will perform well, what you'd best do is to sharpen the reamer on a finger, after heat treat. That would correct any errors in form that might result from heat treat, as heating and cooling metals tends to relax pent up stress, resulting in at least minor movement.
This grinding operation would require a cutter grinder, one that has the capability of turning the table and suspending the reamer between centers, so it can follow the finger properly. That would apply to all forms that are not a straight cylinder, such as a cartridge case. That's the ideal setup. If you don't have access to such a setup, I think you'd be best served by making a test reamer and experimenting to see how close you can get to the cutting edge, to see if you can find a width of circular grind that will perform to your satisfaction. Mind you, I'm not suggesting that you can't achieve your goal without grinding--just that grinding will correct minor issues that may spell the difference between a reamer that performs as expected, or one that yields a poor result.
Heh! Warm is a relative term! We, here on the left coast of the US, are not having it too bad, but the right coast and Midwest are being slammed pretty hard right now. Record low temps and considerable snow. Our thoughts are with those folks.
Post by GlennW »
It should be close to 80 today here, but there may be a breeze, so I'm not sure what the "wind chill" factor will be. 8)
GeorgeGaskill
Post by GeorgeGaskill »
Wind Chill Index. Note that they won't evaluate the formula for you if the temp is above 50° F although obviously the felt temperature is less when a wind blows upon a sweating skin.
Glenn Wegman wrote:It should be close to 80 today here, but there may be a breeze, so I'm not sure what the "wind chill" factor will be. 8)
Best protect yourself against those harsh conditions, Glenn. :lol:
hammermill
fear dehydration :shock: :roll:
steamin10
Post by steamin10 »
Ha! Thats what Minty Julups, Rum Punch, and Bahama Mamas are for. And if it dont hydrate ya, ya dont care anyway!
Make sure about your 1000 Sunblock before you pass out on the beach. :mrgreen:
An effect we found handy was sharpening a tap for a nut threader, and then tapping the end it on a beam, made the hardened material spring open a thou or so, giving us a better life on worn out tapping mandrels. Each tap had to be fitted to a hook, that rode in a spinning head spitting out tapped nuts from blanks.
