Page 1 of 2
Gatling Gun
Posted: Tue Jun 24, 2014 1:42 pm
by solek
I made hit miss engine, from caastings for years, but ran out of kits, I wanted to build, so trying a gatling gun.
Update of how it is going:
The carrier block, for the bolts has .420" holes, whick required buying odd size tooling. If you go to 27/64", only .002" bigger you could use normal tooling.
The carrier block needs square bottom holes for bolts to fit. I used a ground down 27/64" counter sink, to cut bottom square.
The cam drawing is a little tricky, and when using 4 axis mill, we cut a mirror image, so need to make another.
Got DOM tubing for barrels, but talking to some gun people, found out a lot of people buy 10-22 rifles, and change out barrels & etc. Found three, see in picture, and have 8 more coming.
If you have any questions, ask me.
solek
Re: Gatling Gun
Posted: Fri Jul 11, 2014 3:08 pm
by 1911ly
That's a neat project. I am looking forward to updates!
Re: Gatling Gun
Posted: Wed Dec 24, 2014 12:32 pm
by rbertalotto
UPDATES?
I want to build one of these also...
Re: Gatling Gun
Posted: Thu Dec 25, 2014 5:49 pm
by solek
Gun has been on hold, do to lack of cam. Have a friend with CNC mill, That is going to cut it, for me. He made one that was a mirror image, and has not got back, to cut one right.
Need the cam, so I can start putting the parts together, to see if I have made them right.
solek
Re: Gatling Gun
Posted: Fri Dec 26, 2014 11:45 pm
by redneckalbertan
solek wrote:Gun has been on hold, do to lack of cam. Have a friend with CNC mill, That is going to cut it, for me. He made one that was a mirror image, and has not got back, to cut one right.
solek
My knowledge of Gatling guns is very basic. I am assumeing that when you are talking about the cam that is the device which both cocks and releases the firing pin. Could you rotate the handle and barrels in the opposite direction to function the firearm with the mirrored can?
Re: Gatling Gun
Posted: Mon Dec 29, 2014 4:49 pm
by solek
Due to the way, the spent brass is remove,and other areas, of the gun it will only fire, in one direction.
Solek
Re: Gatling Gun
Posted: Mon Dec 29, 2014 8:13 pm
by Patio
This will be an interesting thread! I will be watching.
If I remember right, I thought Pamela had built a Gatling gun in her past. I could be wrong though.
Re: Gatling Gun
Posted: Tue Dec 30, 2014 1:21 am
by Rolland
I made my cam on the lathe and then cut it out and soldered the two halves together. Since I did not have a cnc mill just a manual one at the time. The cam has to be exact or things really hang up. It only took me a year and a half. Making parts in a mirror image I thought was the correct way
Barrels were dom tubing drilled for an insert from Brownell's
Re: Gatling Gun
Posted: Tue Dec 30, 2014 10:04 am
by Dave_C
Beautiful work!
I'd love to make one of those but I'm pretty sure I don't have the tools or the funds.
Dave C.
Re: Gatling Gun
Posted: Tue Jun 16, 2015 3:55 pm
by solek
At long last, the cam is cut. Added the end plate, and cut slot, for bolt removing.
solek
Re: Gatling Gun
Posted: Thu Sep 15, 2016 3:07 am
by rbertalotto
Update?
Re: Gatling Gun
Posted: Fri Sep 16, 2016 10:59 pm
by solek
Hit another rock! You have 10 barrels/bolts, that you have to set head space on. To get it right you have to get the barrel to bolt set +/- about .0005". I have the go/no-go gauges, but get my skills, to the point, to cut the bolts/barrels, right, is lacking! The rest of the parts, work well!
Gun looks good, but it is not a shooter, yet. Someday?
Solek
