Trucks Fabrication
Russ Hanscom
Trucks Fabrication
Post by Russ Hanscom »
Here are a few more shots of parts for a D&RG narrow gauge cast steel frame truck which we are converting to weldments. The bits are mostly 1/2" thick plate, which has been CNC cut and bent. For the most part, the fit-up has been decent and only a little trimming has been needed. We try to work with sub assemblies as long as possible to control handling weight. A completed flying bolster weighs in the 800# range and the central truck frame will be 1200#+
E6010 and MIG are being used for tacking and E7024 and MIG are being used for joint fill-up.
Glenn Brooks
Re: Trucks Fabrication
Post by Glenn Brooks »
Interesting project! How do you control warping and distortion?
Glenn B.
tomc
Post by tomc »
weld slow
Tom C.
tom_at_srclry_com
A student of the Southend RGS!
Russ Hanscom
There are several ways to control distortion. I do half a rod here, half a rod there, to equalize the heating. Being aware of what welding one area is going to do helps plan preventative measures. Sometimes we use a stongback or clamps and wedges to preload against distortion. After a few parts, the process of control is fairly obvious.
johnpenn74
Post by johnpenn74 »
What preheating techniques can anyone recommend?
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
Russ Hanscom
For common steels like A36, no preheat is required as long as the metal is at room temperature and dry. If is it frosty or damp, preheat a bit - not much required. If you are having problems with the root weld cracking then a bit of preheat will help.
If you are working with higher carbon steels then preheat is recommended or required.
A welding specialist once told me - when in doubt preheat.
No preheat was used on the project I was sharing and we are using standard hot rolled stock to 1"+ thickness.
