TIG Progress: Almost Welding
Moderators: Harold_V, Scott
Post by SteveHGraham » Thu Apr 06, 2017 7:34 pm
Today I cleaned up the underside of my treadmill tubing and made a few flat beads on it. As bad as they are, they represent a big improvement from a few days ago. The stuff at the upper left in the photo is from an earlier session. It's the underside of a piece I practiced on. Guess the amperage was a wee bit high.
The latest beads look a lot like welds. They color is dull, and I read somewhere that this means I'm welding too hot. Perhaps someone can comment.
I learned some stuff. Apparently I'm not supposed to keep adjusting the pedal, because it makes the bead irregular. I was moving it a lot in prior efforts because I thought that was the way to fix it when the arc seemed too weak or two strong.
I'm getting a little cratering at the end. I read that this is because I'm shutting the torch down too fast. Sound right?
I'm also holding the torch more vertically, which is a big change. I'm feeding the wire considerably better.
Managing the duty cycle is a mystery to me. I'm just putting the torch down after 4" or so and letting it rest. Do people use timers? My understanding is that I can weld for 6 out of every 10 minutes at some amperage level which I can't recall. In actual practice, it seems like the torch gets hot after three or four minutes, so the welder itself never gets a chance to strain.
I went back to a 3/32" tungsten, and I'm using the same size filler.
I went from a TIG Finger to a BSX Flak Finger, which is a bigger device with a strap that holds it so it won't fall on the floor. It's fantastic.
Weigh in on my welding artistry. I'm trying to make use of all the tips I get.
I need to get some metal that doesn't come covered with powdercoating. I don't think I'm getting this metal completely clean.
warmstrong1955
Re: TIG Progress: Almost Welding
Post by warmstrong1955 » Fri Apr 07, 2017 11:30 am
You are improving! Keep at it!
Maybe too hot, or maybe you are lingering at one spot too long.
Watch your puddle, and each move after a dab in the puddle needs to be the same distance. This takes some practice.
As far as rheostat control....start off with more pedal, then once you get a happy puddle, back off a bit. Should stay pretty consistent after that, with an adjustment or two after a few dabs, and then depending on the piece you are welding on and how much it absorbs the heat, you back off a bit as you weld. Watch the puddle.....size & speed.
When you get to the end, back off as far as you can on the pedal, while still maintaining an arc for a moment, to avoid a rapid cool down. This can cause cratering. Then back off the arc, but maintain the gas till the last puddle is fully solid and cooled a bit more. Shutting off the argon can also cause cratering. I'm guessing your welder has a timer on the gas shut off, rather than a microswitch in the pedal, and you may need to adjust the time a bit.
Of all the welding methods, TIG is the most complicated to learn. Like I said before....a lot going on....both hands, and fingers, and your foot must be in sync.
Did I mention....to watch the puddle!
After a while....things start to become instinctive!
:) Great progress!
Post by SteveHGraham » Fri Apr 07, 2017 1:43 pm
Thanks for the help. I really need to get some real metal and save this junk for MIG.
