I purchased the lincoln PM 300. I have virtually no eperience welding and started right off welding aluminum boxes (48"x30"x18" out of .125 5052 sheets 0.045 5356 wire) with just the push gun.(I did have some holes burned in the plate) It worked excellent as long as you didn't put a sharp a kink in the gun cable. Used the 300 mag gun it came with, 0.045 rollers and steel liner. Later purchased the aluminum rollers and teflon liner but those worked about the same as the regular gun set up. I wanted to get the push pul gun but couldn't afford it at this time . I have lately been trying it on mild steel 1.25 X .125 mild steel tubing and still playing with the settings, but seem to get some real decent welds. Havn't used all the diffferent settings yet but will continue to experiment. I will try to post some pics of the aluminum and mild steel welds for some one to critique, but I think the PM 300 is an awsome machine. just my thoughts steve
