Tiers: Being a professional Millwright, I have to weld. I am quite ameteur at it, having seen good qualified welders work. In critical welding of some jobs, I always ask the better or best welder to finsh weld if possible. If offer these tidbits from my experience.
Shade #: Use the lowest you feel comfortable with, Shade 10 is usually good for small rod, larger rod with stronger arcs may require stepping up. Auminum with Helium is quite bright, and may require more protection.
Lensing and glasses: Wearing glasses can be problematic. As a matter of personal condition, I am near sighted, but the working length of my glasses force me to work far away,not good for details of the weld, or close in without. I have gone to 2.5 lenses in the helm to work this out. I can speak from experience, this is not a memory excercise, You must watch, the arc, the metal puddle, and the following slag or you will never get good welds, except by chance. There is a tendancy for beginners to focus on the Bright cover slag. This is wrong, as the width of the metal puddle is what must be controlled by arc length, rod angle, and arc forward movement. That is a lot to watch and assimialte at one time without experience. Without being able to see these, you are, and will stay lost in the woods without a clue what to do.
You have to be able to see not only the weld, but the shadows of the weld line, to be done.
Rod control is an issue that always changes. Waving a rod at a weld, like grass in the wind, is going to make for a messy weld. Bracing of the holding arm is most common, and done for comfort, as is getting the stinger cable stable so it does not effect the hold of the rod clamp (stinger). Often , for me, it is draped over the shoulder so the weight is lessend at the hand, or draped close by on the work, so the suspended weight is short.
With You-tube and some books, I believe a good idea of approaches and views can be had, the only thing missing is Practice, practice, practice. Have fun a build something. Go-cart, garden cart, Junk art. Just do it.
_________________ Big Dave
Be Alert! The world needs more Lerts.
