The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Wed May 22, 2013 11:08 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Thu Oct 06, 2011 1:39 pm
Offline
I am using an oxy/acet setup for brazing a copper boiler. I had to get inside the boiler for a long session of heating and brazing. The tip got very hot while inside the boiler. I also had a few blowbacks where the torched popped off. When I went to change tips I noticed there was what appeared to be black soot between the two rubber gaskets on the tip and soot on the handle connection as well. This was on the inside of the handle tip connection area. Was this from the blowback or did I over heat the tip?
Top
 Profile
PostPosted: Thu Oct 06, 2011 2:31 pm
Offline
I'm far from being an authority on welding and welding devices, but it sounds to me that acetylene ignited inside the torch, likely due to the overheated components. I expect you were far from a meltdown, otherwise the carbon traces you found would not have been present.
It will be interesting to read comments from those that have experience in this issue.
_________________
Top
 Profile
PostPosted: Thu Oct 06, 2011 4:53 pm
Offline
i would chaulk this up to blowback hope you got the preventers(flash back) at the base of the torch
Top
 Profile
PostPosted: Thu Oct 06, 2011 5:44 pm
Offline
Thanks for the quick feedback. I spoke to Victor and they said it was just blowback. The said to take the handle off and gently wash the area with soapy water and blow dry with compressed air. And fortunately I have the handle with the flashback preventers.
Top
 Profile
PostPosted: Sun Oct 23, 2011 5:54 pm
Offline
Could also be a sign that you are leaking some OX into the gas side. be sure the two seals are in good shape espically since the rubber seals may be cooked from overheating
Joe B
Top
 Profile
PostPosted: Sun Dec 04, 2011 7:00 pm
Offline
A bit of carbon is common. Ensure the seals are smooth and supple, not burnt and crispy.
Victor O-rings are inexpensive and you can swap them from one tip you aren't using if needed by gently removing them. I use a sewing needle to get behind then then pinch them between thumb and forefinger.
I use a brass or plastic toothbrush to remove loose carbon.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
