The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Thu May 23, 2013 10:20 pm
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Thu Apr 05, 2012 7:08 am
Offline
A better source for etching information (from AWS)
http://www.eng-tips.com/faqs.cfm?fid=1111
_________________
Ralph M. Reese
St. Augustine, FL
Under Construction
LE Pacific
Allen 10 Wheeler
Top
 Profile
PostPosted: Thu Apr 05, 2012 10:08 am
Offline
Wheels: the variations in weld bead success are mostly due to the diferences in line voltage to your machine, added to your technique. A small deviation in voltage becomes multiplied out of the machine, making the chart merely a suggestion for a starting point. By Your knowing experience, you get dialed in, by the results you see.
As far as etchants are concerned, it should be noted that hydrochloric acid is a gas, Hydrogen Chloride, with an affinity for COLD water. Created with chilled water of 40* it is saturated at 32%. Muratic is generally 12%, as bottled for stores for pools and common cleaning use. If you do some checking, you will find that toilet bowl and tub cleaniers are mostly Hydrochloric based, some approaching raw concentrations. Muratic is of course used in the household to remove Iron (rust) stains, that are complex iron and calcium deposits, and generally imune to soap based cleaners.
Sound familiar? Boiler wash compounds are normally hydrochloric, and become more aggressive as they pick up Iron as Ferric Chloride. When heated this action is accelerated. Another accelerant is Sodium Chloride. (table salt). Added to Muratic in small amounts, it is aggressive on mineral deposits bearing manganese and magnesium bearing calcates, depostied from boiler waters. This stuff is death to aluminum in nearly all alloys, and will turn near pure aluminum into a black fizzy with a pronounced exothermic reaction. Hidout is a problem with any salt or chemical action, so a neutralizing solution and thorough flush is always recommended. Just FYI.
_________________
Big Dave
Be Alert! The world needs more Lerts.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
