$1.99 Track Cutter
$1.99 Track Cutter
Well, not exactly $1.99, possibly less, if everything from the scrap box is considered free.
I needed to taper some 1 3/4" square bar for some forks I am making for a friend's tractor. For a right angle cut, there are multiple options, but not for a 16" long bevel, and I did not want to do it on a milling machine.
So, two pieces of conduit, some scraps of unitstrut and clamps for the track, some allthread and a cordless drill for motive power, and a simple carriage running on old ball bearings with a few simple adjustments with a holder for a regular torch. I set the tip size and gas pressure per the Victor book and it worked great. Not the last time it gets used, I am sure.
Some of the large lumps are weights to improve stability.
Re: $1.99 Track Cutter
Way cool, Russ! The poor man's track cutter.
- refinery mike
I love it, the only thing I can not see is what did you use on the bottom of the carriage to ride on the conduit.
Mike,
One side of the carriage has several small ball bearings mounted in a V pattern so that they track on the tube, the other side has some bearings that ride on the top of the tube. I have a box of surplus bearings, 3/16 id x 7/8 od. Good for projects like this. The tube in the center is the guide for the allthread.
The picture is a bottom view of the carriage if you haven't already guessed.
Back to back;
The next step is to weld some verticals on the forks. The forks are clamped back to back and the vertical piece is aligned then fixed with a temporary strut. A bit of preheat is applied before welding then a whole bunch of passes are made with 7018 rod. After it has cooled for a few hours, the clamps are released and the forks are straight. Much easier this way than trying to straighten a couple of bananas.
While it was cooling, the track cutter was cutting out some sides from 1/4" plate.
Thanks Russ,
Very cool setup
Ken.
Very cool setup
Ken.
One must remember.
Ken.
Ken.
Russ, This is one of the best ideas I've seen for a while. I suck with a cutting torch, but sometimes there's not alternative. (Sitting here running my scrap inventory through my mind right now.) I see a new track cutter in my future. Thanks.
Chuck
Chuck
- neanderman
What are the standoffs that hold the bolts that act as axles for the bearings? Are they off-the-shelf items or did you make them? I don't recall ever seeing anything similar.Russ Hanscom wrote:One side of the carriage has several small ball bearings mounted in a V pattern so that they track on the tube...
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Those eyebolts happen to be surplus from long ago. You can accomplish the same intent by using short sections of small angle or turning the standoffs from 5/8" or similar stock. Depends on what is in your scrap box!
- warmstrong1955
So.....every now and then, I have use a track torch. I have bid on a few on fleaBay, but they always end up going for a whole lot more money than I care to spend.
So....this thread got me thinkin'....and I made this: Mostly made from leftovers, other than the acme rod & nuts, so it cost more than a buck-99. $45.99 is more like it. I still have to make a lock for the oxygen lever.
- steamin10
Lever lock = bent coat hanger....Done this a hunnerd times.
- warmstrong1955
Well....if you look at my pic....right now I push the lever & stuff a 1/4" bolt thru that shiny galvanized piece of flatbar and away I go.....steamin10 wrote:Lever lock = bent coat hanger....Done this a hunnerd times.
I was thinkin' a little lever, with a roller, that cams over center, might be handy.
