Harold_V wrote:I'm amazed they'd use that grade, and it comes as a surprise that they did, but it's hard to argue with facts.
I used to buy my tech grade (68%) in a 55 gallon drum, one of which I owned. A simple exchange at the chemical store and I was good to go. At that time, I was paying right at $4/gallon.
Tech grade was more than adequate for refining, even silver. Even traces of chlorides in silver nitrate aren't good, yet one could dissolve pure silver with tech grade and distilled water with perfect results (necessary evil, as silver nitrate is the electrolyte for a silver parting cell). Concentration was reduced, but the acid was very white (clear) and free of troublesome contaminants. Makes me wonder why they used such a high level of purity, as cost goes through the ceiling. I learned that when buying reagent grade nitric for making test solutions.
As there was no mention of using sodium dichromate in your comments, I wonder if, maybe, that was their way of avoiding disposal problems. Chromates have become a real white elephant, even for disposal of solids. Any comments?
Harold,
We made all of our own products, and our company purchased top
grade everything, this way no one could mix low grade anything in
with the good. The passivation went very fast (15 minutes) with
solution at room temperature. We all had our own full head gear with
full face mask's that we washed, rinsed, dried, and installed new filter's,
and put back in a new air and water tight storage bag at our work bench.
We had and used one time chemical gloves and chemical suits that we
would cut up when done, so no one could reuse, and then put in to proper
disposal barrels and fill out the paper work on each barrel. If we had to
work in our hi-bred Chromic acid area's we would even cut our new chemical
boots uo in the bandsaw after we washed, rinced, and dried them. then we
would dispose of them in there proper barrel and do the paper work.
In regard's to your chromate question. Easy answer, and a long story short.
The City chemists would pull their little white van up to each of the two
man hole covers we had in front of our plant and take water samples
twice a day un anounced and test them. All chemicals and water were
deverted to the center of our plant where it was tested, treated, and
broken down chemicaly and made safe. All water remaining was drinkable.
All the bad sludge was pressed in our sludge presses and put into the
apropreate drums and sealed. Paper work filled out and off to the EPA
aproved burial ground. All of our ingredients for the products that we
made had a paper trail from our suppliers into us and through and with
our products to our customers, and when they were done with the product,
we would pay to have it shipped back to us for break down and disposal.
Oh and the paper trail would never stop until the products were cleaned
safe, and buried with the paper work at the EPA approved site. All toxic
fumes from our air tight production equiptment went out to a large after-
burner on the roof and was burn off at 1600 degrees to zero toxins. The
Chemists would climb up the stack and take readings every 30 minutes
and do their paper work.
Lots of Paper Work. All Plant air in was fresh,
filtered, humidity, and temperature controlled makeup air. All plant air
going out of this plant was pulled through 20' high scrubbers with D.I.
water spraying down through poly ethylene media. All the run off scrubber
water went to the center of the plant and got treated before it left the plant.
Well I hope I didn't bore anyone. please excuse any and spelling error's and
or letter form etc.
Thank You for bringing back memories. This was a GREAT PLACE to work.
Ken.
