Dimples
Moderators: Harold_V, GlennW
Russ Hanscom
Dimples
Post by Russ Hanscom » Mon Dec 26, 2016 2:49 pm
Got an old Landcruiser FJ 40 that had holes rusted in the floor pan. First attempt was to order a set of replacement panels that came with really wimpy dimples, nothing like the originals, so...
The floor plan plate took four 1 1/2" x 8 1/2" by 3/16" deep dimples. The plate under the pedals took a 1/2" x 12" x 1/8" dimple. Here are the results at this stage - the dimples came out just right - nice and crisp. These were made with simple metal dies - two plates with the male form on one side and the female form on the other side with some alignment bars between the two then a quick trip to the press. The plate is .030" thick. One dimple at the time for the four dimple part.
I have also used hardwood forms and have one going for an odd shaped dimple to cover the clutch slave cylinder.
Re: Dimples
Post by BadDog » Mon Dec 26, 2016 6:27 pm
Nice work.
Russ Hanscom
Re: Dimples
Post by Russ Hanscom » Sun Feb 05, 2017 6:01 pm
Not my favorite sport, but it needed to get done.
Dimples done, the panels got welded in; lots of plug welds to attach to stuff below.
Once the floor pan, the trans cover had a rotted edge that needed to be replaced. That is now ready for final grinding and a spot of primer. Since this is an offroad vehicle, a few muddy shoes will cover up any imperfections!
