HF Sheet Metal Brake
Moderators: Harold_V, GlennW
deltaenterprizes
Post by deltaenterprizes » Sun Nov 03, 2019 8:40 am
I bought a HF sheet metal brake and I am making fingers to make a more versatile.
I bought some 3”d1/2” flat bar at the scrap yard and would like to know what sizes would be best to make the fingers.
The total width is 30”, I have made 1,2,3,4,5,6,12 & 14 inch pieces so far.
The fingers will be held with “C” clamps like the pice that comes with the brake.
J.Ramsey
Re: HF Sheet Metal Brake
Post by J.Ramsey » Sun Nov 03, 2019 3:20 pm
Make them in sizes that you think you will need.
My 4ft.Tennsmith has five 2",six-3" and five-4''
Post by BadDog » Sun Nov 03, 2019 5:18 pm
I would say make them in stacking cumulative sizes kinda like very coarse gage blocks.
1", 2", 4, 8, etc.
That allows all widths from 1 to 15 by increments of 1" with no redundancy. Wouldn't be as rigid/strong, but maybe throw in a 1/2" if desired for very light work that doesn't work out to integral inches.
Post by SteveHGraham » Sun Nov 03, 2019 8:38 pm
If the widths are all integral multiples of one inch, it will be impossible to make things like a 4.5"-wide box.
J.Ramsey
Post by J.Ramsey » Mon Nov 04, 2019 4:51 am
A 4" finger will make a 4-1/2" wide box just fine, I you are that worried use two 2 inchers spaced apart .
Besides you cannot make a 4-1/2" box with a 4-1/2" finger it will be oversize by the material thickness.
Post by SteveHGraham » Mon Nov 04, 2019 9:11 am
You are going to be better off with pressure on every part of the crease.
I think we all knew that material has thickness, and I didn't say "4.5" outside width."
J.Ramsey
Post by J.Ramsey » Mon Nov 04, 2019 9:36 am
Well,I guess I've been doing it all wrong for the last 45 years thanks for pointing that out.
Post by SteveHGraham » Tue Nov 05, 2019 10:35 am
Always nice to wake up to a polite and patient response.
b4autodark
Post by b4autodark » Fri Jan 17, 2020 8:42 am
Nice clean shop with a nice layout of equipment Mr. Ramsey!
