Re: Why is my lid jig a miserable failure?
Posted: Wed Oct 15, 2014 10:55 pm
A technique I use to anneal aluminum is to deposit a light to medium coat of soot from a acetylene only torch flame to one side of the sheet metal, then add oxegen to the flame and burn off the carbon. You need to keep the torch moving quickly to avoid overheating any one spot which could ruin the metal. Air cool and it will be soft. Forming or shaping the metal by stretching and shrinking work hardens the metal and the process can be repeated if necessary.
This can also be applied to aluminum tubing which I find a lot in 6061, prior to bending in a tube bender where 3-6" center line radius bends will crack the tubing.
