Sitting in a slightly boring hotel weekend before last I took a 2D drawing out and went about converting it to 3D.
As I am working with AutoCAD 2002 the process is rather dated along with my inability. There is no auto process to convert. The spokes are an example of the hardest to do as they are not square in any plane.
These photo show the method I followed. I was not working to any detail level. Only a rough order effort to upload to the Shapeways Website for a price quote.
First I worked on the concept of a two part pattern to be mounted on the front and back of a match plate. secondly it would be a complete pattern set made by the Rapid Prototype modeling method.
Inititail effort was on the outer rim models making both of them hollow to cut the cost of the models. On RP work you pay for the Cubic Centimeter for the material. Hollow is cheaper.
I quickly came to the conclusion it is easer to draw the various asemblies and stick them together on the centerline. First was the rims. Then one spoke that I pasted in 17 times. Then the hub and counter weight. Nothing is bonded together or radius for joints in at this point. The AutoCAD 2002 does not do filiting very well and if I went this route I would fillet the patterns with wax
At the end of the day I have a rough order of magantude on cost as being somewhere around 350.00 each for the two different sizes for the drivers. Cost is a little prohibitive at this point. Needing only two heavy drivers and four light ones this project, while a good learning experiance on CAD, will go in the recycle bin for now. I am talking to a modeler in Florida who may have 73 inch drivers that I can use as a casting pattern. While they are not exactly as the Fitt Drawing show, they do match the PS-4 in the Smithsonian. This engine does not have the webbng between the spokes.
If the drivers in Florida do not work out i may have to pursue the pattern route.
If I do I will start from scratch to cover some of the issues that Trainman showed me in my drawings.
