New blower
mfletch
New blower
Post by mfletch »
My old setup was useless I started again the problem was it needed a blower so here are the pics of the new blower and what a difference it has made.
Bouncy castle blower
A cut off peace off a down pipe and rubber coupling
Holes to control air
Adjusting sleeve
Fitted a handle for easy movement of sleeve
End reducing for blower pipe
All done and works great
Re: New blower
Post by SteveM »
Nice job on the control valve. Easy, simple and cheap. Kinda like me :-)
RONALD
Re: New blower
Post by RONALD »
When the Mifco blower on my Mifco B30 furnace went bad I inquired about a replacement, they wanted several hundred dollars for a cast aluminum blower. I then found a cheap Chinese blower on eBay for which I paid just over $50.
Turns out it worked just fine, so I have been using it since. I cast outside, so it is detachable for storage.
Of course, it has an all plastic housing, which does not offer much protection if I splash metal.
http://www.mifco.com/
mfletch
Re: New blower
Post by mfletch »
Looks the same blower mine was £20 + £9 delivery off ebay your setup is much larger than mine
