motorized casting machine problem
andychar
Post by andychar » Thu Dec 17, 2015 3:38 pm
I have a very old Romanoff ,motorized, broken arm casting machine. I have been successfully casting sterling silver or bronze with it for several years.
Last cast of a 4X7 flask the machine began hammering loudly, and vibrating badly, as if out of balance. (The casting arm had been balanced correctly.)
I quickly shut down, and removed the casting arm,to check the motor and drive. All was smooth there.
The hammering sounded as if the broken arm would swing from the start position, hit the stop on the casting arm and recoil to the start position.
I don't understand how the broken arm could recoil. Centrifugal force should keep the flask and arm straight out. (Could the ball bearings in the broken arm have anything to do with this?)
If any one has experience with this machine, I sure thank you for any advice or suggestions, Andy
Re: motorized casting machine problem
Post by Harold_V » Thu Dec 17, 2015 4:20 pm
I have owned one of them since the mid 80's, but it has yet to be put in service. It was purchased with my retirement in mind. For that reason, I most likely won't be able to provide much guidance, but one question does come to mind. If there is a stop that prevents the arm from going past center when the centrifuge is activated, is it possible yours has broken? The arm may be oscillating back and forth, seeking center as it spins.
Just thinking out loud.
andychar
Post by andychar » Thu Dec 17, 2015 9:58 pm
Thanks for the thought. The sound is, as if the broken arm is oscillating back and forth between the stops, like you said.
Nothing appears to be broke. The iron casting for the broken arm is very heavy duty. I will try to take a photo this weekend. I am new to the forum, and not sure how to post an image. It shouldn't be too difficult.
I love the machine. It is real well made, and has given me a lot of good service.
If it is of any interest to see what I use it for, some of the items I make can be seen at http://www.oldworldbronze.com Andy
Post by Harold_V » Fri Dec 18, 2015 4:34 am
I took a casual glance at mine today, and found that the stops are rather robust. Not likely to be broken, but if there's not much friction on the joint, I can't help but wonder if, maybe, yours is bouncing. What I don't understand is why it would start doing what ever it's doing so quickly, after serving you so well for so many years. Might not hurt to dismantle the arm to see if anything is amiss.
I took a look at your site. Some very nice things being made.
I'm curios about the large torch you're using in the video. Is it a Hoke torch, or is it just a welding torch with a rosebud? I used to have a large Hoke, but it went with the business I sold (I refined precious metals). It is no longer provided by the source from which I made my purchase, and I have been unsuccessful in finding a new source. Sad thing is, I don't recall the brand of the torch.
If you discover the problem with your centrifuge, please make mention. It might prove useful to others.
Pictures are added to the board as attachments. You do that by clicking on the button below the box in which you compose a post. If you use subsilver2 as your board choice (it's the default choice), there's a wide blue line below the box, with Upload attachment in the line. Just follow the instructions. It's very easy to do. Clicking the Browse button allows you to select the picture you wish to post. You can add more by repeating the action. Make sure they're not larger than 1024 pixels in either direction, as the board won't accept them. It's also a good idea to ensure that they are not overly large in file size, as many, here, are still locked in with a dial-up. Large pictures tend to render a thread useless to such individuals.
andychar
Post by andychar » Fri Dec 18, 2015 7:07 am
hello Harold,
The torch is a welding torch with a rosebud. I had it made up by " Browns torch and regulator repair" here, in Phoenix Az. As I recall, I believe it was about $135.00. I use propane and oxygen,however we tested it in Browns shop, and it worked as well, with natural gas.
I did dismantle the arm, and it has ball bearings, in the joint. It seems as if the arm has to move very freely at the joint. I thought it possible, the grease might be burnt out of the ball bearings, and they are stiff. ( I will check that out today )
When I find the cause of the problem, I will post the solution. Thanks for the photo post info. Andy
andychar
Post by andychar » Mon Jan 11, 2016 12:53 am
I found the problem, and repaired it. The ball bearings in the broken arm were frozen, and the race had worn a groove in the axle bolt. I replaced the axle bolt and ball bearings.I don't know why this caused the machine to knock so badly, but it works fine now. Andy
Post by Harold_V » Mon Jan 11, 2016 2:48 am
Amazing! And, well done!
One never knows how a device will respond to mechanical problems.
You may have provided guidance for others who experience the same problem. Thanks for posting.
