Hi Lads
I have found some of the photos of my , furnace/foundry set up build ,,,,,, some may fined something of interset in them , first off , when i build stuff like this ,i don't work to any real plan , just an idea in my head of what i am after , what materials i have at hand or can scrounge up, thats why things end up the size they are .Some times i get lucky and things work out ok .
I have always loved casting my own parts ,its great to recycle crap into some thing useful , anyway here is a few shots of my old furnace set up, i built it many years ago from bits and bobs from the junk yard , i did splash out and by a new elctric motor for the blower unit i made .
Some of the castings produced with the furnace ,The furnace works great doing ally to iron , just it was a bit small in capacity .
Getting to the piont , i want to do bigger castings/ pour more than one or two castings in one melt , so i need to make a furnace to take diss A16 crucible or bigger
I started with an old chemical drum , the type with a seperate lid ,18" dia ,cutting a section off to make the mian body , and a section for the lid so the bead run in the middle of the lid , this is so the castable has some thing to key too
Not wanting to waist the loverly rolled bead of the top of the drum i trimmed it up and fitted it by spot welding , to the main body , to make it a bit more rigid
Then i made up the lid lift / swivel lever , this works of a cam on the lever and pushes on a rod fixed to the main body , when the lever is moved down the lid lifts verticaly 1/2 " and is easerly rotated out the way
Next the rod for the main body , and some handels
The blast pie
all the metal work done
the center former
If your still awake , now its time for the castable , i filled the bottom of main body 3" thick , let it go green ,then fitted the center form
the lid ,much of the same
The former removed
The lid was fitted and ajusted to give a level lift and some clearance between the cam and rod so the lid will seal flat on the body
I made up a trolley for it so i could wheel it out side ( not my best idea /british weather ) also the plants were not too happy
It did not stop on the trolley long , after some thought , i decided that i must have it so i could run the furnace indoors , after lots of messing about trying different ways of getting the heat out the shop , melting parts of my new shop , i decided to add some insulation to the main body and exhust the hot gasses out the back of the furnace through the shop wall . so a new stand was made , handels removed and lever repostioned .
Moulding sand storage was always a problem , i used to store it in big plastic drums , bit of a pian in the butt , so i knocked up a moulding bech with sand storage built in , works much better , sand dose dot get everywere now , and not in shot is a small adition to the bench which has a joiners vice fitted , so the moulding bench doubles up for patten making
Now the British weather is not a problem
Hope that was not to long of a post
Regards Rob
My foundry set up
Re: My foundry set up
Hey Rob,
Very informative and interesting post, but the images cause the text to spill off the page. Can you resize the photos so this doesn't happen?
Thanks,
Thanks,
Chattanooga, TN
Chattanooga, TN
Everything really looks professional, both in design and manufacture. I would take it all to be factory built. You do good work.
Don Young
Don Young
Don Young
The photos have been posted within acceptable limits, but they were posted such that two displayed in a common line in a few occasions. I have edited his post such that they now appear single file, so you should be able to read the post without text spread. Please advise if that is not the case.Fender wrote:Hey Rob,
Thanks,
Rob, I can't thank you enough for such a fine post. Your furnace (prior to adding the external insulation) is very similar in design to one I built a long time ago. It sure brought back some pleasant memories for me!
edit: clarified comments on the furnace
excellent and i like the tru wall venting and stack idea.
- steamin10
Any through wall design will have an inherant fire danger, if nothing but from prolonged radiant heat, and a furnace may run steady for hours. Careful consideration must be given to this problem. My planned dedicated space for a foundry has a galvanized hood of some size to be fitted with a blower to mix and evacuate smoke and hot gas from the area to the outdoors. It is a reclaim from a restaurant kitchen, flat in back and angle in front. About 36" by 6ft. A puffer fan blower unit will create a draft to move things along. This could be a salvage from a window AC unit, and made to venturi into the exhaust to avoid high heat levels through the unit itself, since it will be most likely plastic.
