bluechipmachineshop wrote:
I started off with charcoal which required alot of tending.
Virtually all of my experience with melting revolves around precious metals, although I have a keen interest in foundry work in general, and will pursue that in the near future, assuming I live long enough!
I'm at the tail end of a house building project that has taken many years longer than I could have dreamed, so time is running out.
Anyway, I'd like to offer a couple comments. Please do not misunderstand them as being critical of your choices---but I think they'll serve to improve your degree of success.
Lets start with your crucible. Molten metals are very strong solvents of other metals. So much so that those that don't melt under a given temperature are often dissolved by the one with which it is in contact. Therefore, when you melt aluminum in a steel vessel, you're contaminating the aluminum to some degree. Many will argue the point that it doesn't matter, but it alters grain structure and can lead to low quality castings. If you're really sold on using steel instead of a graphite/clay or silicon carbide crucible, you might consider using a refractory wash on the inside to minimize contact of molten aluminum with steel.
You can improve the efficiency of your furnace by providing a lid with a small port on top to vent the gasses. It would be difficult with the current furnace you have, and it's likely not a big issue, but if you pursue casting of brass, it will require a lot more heat and may be difficult to achieve without retaining some of the heat that's being dumped to atmosphere with your current setup. It's fairly easy to fashion a lid that pivots, so you don't have to worry about finding a place to set it down when it's red hot. It simply pivots to the side, out of the way. I've built a few furnaces with that design and recommend it highly.
I have used natural gas and forced air for all of my furnaces, including a tilting reverberatory furnace that was used in my refining venture. That is no longer an option for me, so my future furnace (for casting bronze and aluminum) will be fired by oil. I am not versed on that type of burner construction, so anything you learn along the way would be gladly received, and I'll be willing to share anything I learn if it's of interest to you.
Quote:
I'm hoping that one of you guys can send me in the right direction on de-gassing agents and flux. I've heard that pool chemicals work pretty well for the home caster, and are easily available. Any suggestions are greatly appreciated.
Because my experience revolves around precious metals, I know little about fluxing aluminum, so I hesitate to comment. I know it can be degassed by percolating nitrogen gas through the heat prior to casting, which is my intended method, assuming I get that far.
I'd like to welcome you to the Chaski board. Lots of great guys here. We're a laid back group---we try to be kind and gentle, and we tend to keep a low profile. Hope you enjoy your visits with us.
The ingots of aluminum you poured look very nice! Did you melt a variety of waste materials? I've read that bar stock doesn't lend itself well to casting, so I'm curious about what you're using. The picture of the feed wasn't really very informative---looks like aluminum plate on top, in the furnace. Having read a little on the subject, I'm lead to believe that aluminum high in silicon is a good choice. Pistons from auto engines might be a good source. I'd appreciate your comments in regards to feed stock.
