Harold wrote:Bottom line is, you're better off finding a buyer for the cats than you are attempting to make a recovery. You won't realize full value in either case, and the work involved in processing is complex.
I don't have an issue with that idea.I will agreee with you on this 100% but sometimes people just enjoy trying new things just to see if they can.
What I find astounding is your assessment of me and my thought processing. If you knew me, you'd understand how wrong you are, but you don't. It's clear to me, as well as to at least one of the readers on this board, that you're quick to settle for results that may or may not be acceptable. I ran in to this problem when I tried (in vain) to hire help with the building project I am completing. All too many are willing to grab one's money and run, turning out less than acceptable workmanship. I'm not suggesting that that is the case with you---as I don't know you, just as you don't know me----but I'm well familiar with folks who fancy themselves as being skilled in areas in which they know little. They are not capable of making sound judgments, as they don't understand the ramifications of not having the knowledge required. Processing cats would be an excellent example of what I speak.Harold your negativity on what one can do in a home based setting is aboslutly astounding.
You're reading in to my thoughts far more than I've disclosed, and you're wrong, once again. At what point did I suggest that the charge will absorb too much carbon? I didn't say that, nor did I infer that. What I did say is that the prolonged heating (typical of a furnace that is not truly capable of melting iron) changes the chemistry of the charge. That's fact, and all the fancy dancing around the issue won't change that. If that was not the case, adding ferrosilicon wouldn't be a solution.I find your thought process is a typical of some who concentrate solely on one portion of a printed text that... well lets just use the iron melting in a crucible for example. Your reading has indicated that iron will absorb carbon from the crucible changing the composition of the melt and that you would not melt iron in a crucible because of this. Now my question to you is how much carbon can it absorb from the crucible and at what rate.
Best have your floor reinforced. That 50 kw induction furnace weighs nearly 4 tons. It is not current technology, but a second generation machine (motor generator, not solid state). And, it requires a 400 amp 240 volt three phase service. On the positive side, it operates without emitting pollution, unlike a cupola. It also requires that one have knowledge to operate the device successfully, just as one requires knowledge to operate any device successfully. It should be noted that it can kill the operator.The point I am trying to make here is that you dont need to be pin point accurate to enjoy what you are doing. Are there better ways of doing things? Of course there is, but not everyone has access to or can afford a 50kw induction furnace so we use what we have and can afford, and I doubt my neighbours would find a copula entertaining (but I sure would). But hey anytime you want to part with that furnace you just mail it right on over i would love to see it under my tree at christmas
You might be better served discussing things you know that relate to the basic topics of this board instead of second guessing me on matters in which you know nothing (like knowing me). I strongly advise you to do so.
