C Pipes: I was speaking to the thermal shock of a dead cold vessel being thrown into the path of a good hot running furnace. I think it risks cracking the vessel. Myself, I prefer to 'Pilot fire' the furnace for a few minutes to warm up the brick and my empty vessel, as I believe the warming of the brick saves some deterioration of the furnace walls. My home built aluminum furnace has shed the 1/2 inch inner coating, and shows the firebricks that are the mainstay of the layed up liner. They have not changed in so many years, but I dont push them hard until the blower, and gas valve are opend fully. A few minutes warm the furnace and my vessel, and then I charge the cold scrap by tongs, (ok I cheat and toss in small parts.. and miss once in a while) but never spalsh if I add when the heat starts to lower level by melting down. (my home made aluminum furnace is actually Propane and responds across a range of gas settings, and is unblown. It will not run up to brass temperatures, as the oriface for the double venturi burner will not admit enough gas for the BTU load.)
As far as Making your pattern and having your gland material, it ignores many hours of preparation that has gone before. Consider if you called the foundry, and told them to have a 4 lb bar of such and such, can you have it by Tuesday? Good luck. It is the reason so many commercial foundries will simply not deal with hobbiests, who tend to be unresonably naive about getting something cast. IMHO, if I were to supply working parts to the hobby, my focus would be getting the patterns to perform, and then turn it over to the everyday experts, for production. Understand that with enough refinement to your equipment, they cannot do much more than any home shop guy that mirrors industry. Think of it as a home lab, and you have final control with quality, and they cant pass off bad shrinks, or porosity, from slipping practice, or the attitude that 'its only a hobby guy'. There are pitfalls, in an imperfect world. I take the quality enhancement, making modifications right where I see it, (development) as the core of what I need, and my hands on direction. ( Am I King in my world? um, more like Emporer).
Ugh! When I say a 10% addition of zinc, that is a Swag on many times melted brass. This is where I am relying on color of the bar revert, as loss of the zinc will darken the alloy as more copper becomes evident. Go to the book table and see that #44 compostion has but .5% pb, and any adjustments are to bring the copper down to master levels of 83-87%. Zinc is 14-17%. That is why I have a sample board that is polished for brass, and can compare visually while I work to tighten my scrappy standard. Its why pouring a button underwater, can give me a great read on what you have.
Now I have to throw out there, I have been talking about BRASS. When we add Tin, now we have bronze, and that entails a list of diferent metals in the alloys and require controls to keep the alloys true in compostion, to match the tasks demanded. Gunmetal is a bronze used for bushings on copper boilers, and is good for many heated parts, because of its strength, and ability to silver solder well. #63 is the general utility alloy, Cu 86-89%, Sn 9-11%, Zn 0.25%, Pb 1 - 2.5%, Phos 0.25. At 30Kpsi it is strong, and willl not shed zinc and weaken at threads, because there isnt any to speak of.
Now that I floated one in the punch bowl, you can see why a pro using bar metal is the way to go for consistancy in the technical world. I have no way at all, to truly assay my feed stock or what I create in the crucible, which is always the major caviat for the home guy. This is why I say to measure everything by weight, and explore the tables for close alloys and their properties, to educate my guess for where I want to be. ( There is reported to be a Star Trekky gun, like a heatgun, that scrap yards use to determine approximate metal composition for non-ferrous metals. I have no knowledge of this device)
So far, I dont make many critical parts, so a thumbs up SWAG is good for my use. Your milage will vary according to your attitude and how skilled you are at making good estimates on the technical side of building things. Thats why all this is much more than just making lead soldiers in a mold. Weren't those fun? Worry Warts would have a COW if those were on the market today. Remember the toothpaste in the lead tube? A lot went down the drain so I could get my new Generals in line.
I hope this helped with your questions. It is my view.
