Gating and Rizer Question.
Having never done a ring type mold I am asking for guidance on the way to run Bronze into this project.
It will be a brake ring for a 2 1/2 inch scale Live Steamer. The diameter of the ring is 6 inches.
the plan is to mount them rings on both sides of a match plate. I had thought I would bring the metal into the center with four gates out to the ring. Thin put in four pop-offs around the ring to let the gas escape.
Any suggestions
Any suggestions
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
Re: Gating and Rizer Question.
how thick is the pattern to be cast and which bronze will you be useing?
The pattern will be 3/4 inch thick with the tabs being 1/2 inch.
Charlie Pipes
Current Projects:
Current Projects:
Saw the second question. It would be junk bronze from the scrap box
Charlie Pipes
Current Projects:
Current Projects:
There's a lot of different brasses and bronzes out there. You might be in for a bit of trial and error to get the pouring temp right, but you can't complain about the price...
Having cast brass and bronze scrap for years I have found that the round number of 1850-1900 will usually get me a part. Not a sellable, perfect, part by any means, but a part
Charlie Pipes
Current Projects:
Current Projects:
I do have some silicon bronze ingot left. Question of how good a brake material would it be?
Charlie Pipes
Current Projects:
Current Projects:
No idea... I'm thinking a yellow leaded brass, but with all the guys on this forum building trains someone must know what's best to use.Pipescs wrote:I do have some silicon bronze ingot left. Question of how good a brake material would it be?
DavidF
As to your drawing, you are feeding at the bottom with a large riser in the middle of the ring?
Charlie Pipes
Current Projects:
Current Projects:
Yes. I'm sure there are other ways to gate it, but this is how I have done similar in the past.
On the Alloy Avenue form you might want to look up the member HT1, he has a great deal of experience when it comes to gating bronze castings. Never hurts to have a second opinion....
This is a much bigger piece and they don't show the gating, but it may give a few clues
http://www.youtube.com/watch?v=5aw7rd3Msto&t=16m48s
This video is unavailable
