Need tp locate small Pentagon female bits or sockets
Re: Need tp locate small Pentagon female bits or sockets
I've found security driver ers in electronic stores. For example: MRO, and Active Electronics.
Good suggestion, but I don't have the knowledge skill level or tools to accomplish that. But I would like to learn how and would probably invest in those tools because I am often running into this type of problem.dly31 wrote:It might be feasible to make a copy of the screw and use it to hot forge a fitting socket.
"When you have both a secret government and an open government -- you have a secret government."
I suggested that because I have heated worn out Phillips screwdrivers and hammered them into new screw slots and it restored the tip shape pretty well.
Don Young
