Why People Prefer Imperial to Metric
- SteveHGraham
Re: Why People Prefer Imperial to Metric
Okay, time for more conflict and angst: what about manufacturers who are too lazy to make true metric or imperial stuff? How many 12mm wrenches are really half-inch with a different stamp on them?
- warmstrong1955
None.SteveHGraham wrote:Okay, time for more conflict and angst: what about manufacturers who are too lazy to make true metric or imperial stuff? How many 12mm wrenches are really half-inch with a different stamp on them?
13mm maybe....but not 12mm.
- SteveHGraham
You think they're putting "12mm" on 13mm wrenches? That would be pretty slippery.
- warmstrong1955
Too many cocktails with the turkey Steve?SteveHGraham wrote:You think they're putting "12mm" on 13mm wrenches? That would be pretty slippery.
- SteveHGraham
Well, think about it. After some black coffee.
- warmstrong1955
We have got to get you off the nog Steve......SteveHGraham wrote:Well, think about it. After some black coffee.
You can more often than not use a 13mm or a 1/2" wrench on either a M8 or a 5/16" capscrew, although sometimes the 1/2" wrench will be a bit tight.
Doesn't work that way with 12mm & 1/2".
- SteveHGraham
You can use a 1/2" wrench on 12mm. You can't use it on 13mm.
- warmstrong1955
Disagree.....SteveHGraham wrote:You can use a 1/2" wrench on 12mm. You can't use it on 13mm.
In most cases, you CAN use a 1/2" wrench on a 13mm. I've been doing it for years.....a lot.....often.....including day before yesterday on my band saw. .
Sometimes it's a snug fit, and sometimes you run across one that the 1/2" wrench or a socket that won't fit.....although, I've been in a pinch with a close fit and tapped 'em together.
On a 12mm.....awful lotta looseness going on. A 12mm hex is .474"/.480" (ISO std)
Pretty poor fit to a 1/2" wrench. Better not be tight.
An open end 1/2" wrench is .504"/.510" (ANSI std) Cheap ones tend to be oversize.....
13mm hex is .501"/.512", (again, ISO spec) most tend to be at the smaller end of the tolerance, which goes for most imperial fasteners as well, which is why more often than not, the 1/2" wrench fits the 13mm hex.
- SteveHGraham
I don't know, man. That seems like a lot of research to back up something you said while the Pink Ladies were in effect. I don't think a manufacturer would sell a restamped wrench that goes over MOST 13mm hexes. It would be a real bummer, knowing that all of the "13mm" wrenches you sold were likely to come back as returns. Even Harbor Freight might hesitate.
But in reality, it seems like it usually goes the other way, with metric stuff relabeled SAE. I will admit, I didn't actually get out the calipers and measure wrenches and fasteners prior to commenting. It was more like I was killing time while waiting for the pain of eating 5 pounds of food to subside.
If you want to argue some more, I'll run down to the liquor store. I'll see if they have Capt. Morgan's rum with a Robertson-drive cap.
- warmstrong1955
When you get the Capt'n Morgan, pick up some apple cider too.
A shot a Morgan, a cup of cider, nuke in microwave for 1 minute.....and you have something that's good for what ails ya.
I didn't measure anything....the numbers are what I have in my computer. Collected when I was measuring and testing a hardware several years ago, for approval.....or in some cases....NOT.
If someone was to want to make a wrench that fits both, and brand them one way or another, or both....13mm to 1/2" would be one of the easy ones. As it is, 19mm & 3/4" are interchangeable. (Do the math)
To make a 'fits both' wrench, the open end would be measures .513/.514" wide. That's the bottom end or .001' over on the ISO spec for a 13mm open end, and .001"/.002" over the max ANSI spec for a 1/2". Close as many wrenches are made. I can go measure a dozen different brands if ya like....I have many.
1/2" wrench compared to a 12mm hex would be .020" to .026" loose, assuming the wrench measure .500".
If I had a wrench that I bought that was that loose, I would take it back.
No argument......
No argument......
let us not forget the universal wrench sets as seen on tv. ah the confusion of it all. where is the humanity.
The only things are that 17mm is close to 5/8" and 19mm is 3/4" . 8mm is close to 5/16" but usually good quality tools don't allow this. Often, however, a worn out hex or 12pt will actually fit a worn metric. It may be the last thing it does and that's better than nothing. One thing is 10mm and we have many of them for a reason. octal day.
