Fire wood
Fire wood
I am starting to feel old , I spent today cutting firewood . I used to enjoy it .
But today it didn't feel like anything but hard work .
In a normal year between the house and my shop I burn about 7 chords of wood .
With the bulk of it used in the shop .
In the house I only use it for supplementary heat when it gets to cold for heat pump to be efficient .
I have almost two chord left over from last year , and I got at least a full chord cut and split today , maybe a smidge more .
So only five more to go for this year , but as I'll use up what easy to get standing dead wood to meet this year's needs ,... over the winter I'll have to start cutting for next year . Sooo... I guess that's only 12 more to go .... uuhg
- neanderman
Re: Fire wood
Seven cords!!!??? Holy backache!
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Re: Fire wood
Well I have known.. bitter bitter cold in northern N.Y. but only a miniscule piece of it. Those valleys where snow was constant and electric heat was expensive. Dang man. Tons of firewood . I used to talk about cherry and grains and patterns inside maple and stuff. He's like, You come over here and cut it. ( He had 50 acres) . Cut it down, haul and cut again then split it..over and over. Then his kids grew up and everyone had a car and they split.
Re: Fire wood
I sure hope none of it was elm. When I was a kid, my granddad had only a wood burning stove in the living room. (Also no running water. The house was built in 1850 or so. It was 20 years older than grand-dad who was 3 when Custer disbelieved his intel.) One year he had a lot of elm wood. I spent more time prying the wedges and axe out of the elm than I did actually making stove wood. Geez but I had hoped to forget that.
--earlgo
--earlgo
Re: Fire wood
Ah the joys of a powerful gas/hydraulic splitter! We shared the cost with our neighbor and we're both happier for it.
Makes splitting a cord of wood pretty darn easy.
I recommend such a solution.
Re: Fire wood
My days of using a splitting maul or wedges are long gone ... I have a log splitter .
Elm can still be a challenge though if the tree has more twist then normal .
Most of what I have been cutting is ash , the emerald ash borer whiped out just about every ash tree on my property that is bigger then about 12 inches in diameter .
If I have to drop trees for firewood I normally stick with oak , hickory or locust .
I figure if I'm going threw the work I might as well get the most heat for my effort .
- steamin10
Re: Fire wood
Thanks for the reminder. I have two log splitters that need engines. because of the mainteenance headaches of keeping all my small engines running, I am considering a pto shaft driven pump.
in that mode of thought, a dutchman pad on the drawbar socket to mount the pump right on the pto and extended hoses would do nicely without a long shaft hanging out around the tractor. I would use my diesel compact of course.
- warmstrong1955
Re: Fire wood
My wood comes in bags.....
No splitting required!
Bill
Bill
Re: Fire wood
Let me recommend the easiest fix for small gas engines on a log splitter .
An electric motor !
That would be assuming that like me you do most of your splitting at home near a power source .
It sure is nice knowing that you park the splitter for 8 months and when your ready to use it all you have to do is plug it in and flip the switch to make it work .
No more gummed up carbs , no more yanking on a rope to start it .
Mine is quiet enough you can carry on a conversation with it running .
It was stunningly simple to convert .... I used a 7.5 hp three phase motor . I had to drill 4 new mounting holes and buy a love joy connecter . Less then a half hour of work .
If you have two splitters you can have the best of both worlds , one for the big stuff out in the woods a gas engine or pto powered . , and one for everything else at home .
An electric motor !
Re: Fire wood
Makes perfect sense -which eludes me at times. This house had two huge elms in the front yard. Grand trees but they got the elm disease and died fast. Back in those days, I went up my Dad's 20' ladder and cut them down by any means necessary. Burned a lot but dang! getting there. Elm was the wood they used for wagon wheel hubs and stuff. Couldn't even split ( with wedges and sledges) it unless half rotten.
