Page 5 of 7
Re: Tractor v. Diesel Pickup
Posted: Mon Aug 13, 2018 12:05 pm
by SteveHGraham
Thanks.
My biggest problem right now is poison ivy. I have areas that are carpeted with it this year, and to kill it with Roundup, you have to buy the expensive kind. You know how Roundup works. They sell two versions. The expensive version, and the version that doesn't do anything.
Posted: Mon Aug 13, 2018 12:11 pm
by John Hasler
SteveHGraham wrote: ↑Mon Aug 13, 2018 12:05 pm
Thanks.
That's not how it works for me. I buy 2.5 gallon jugs of Kill-Zall concentrate (41% glyphosate), dilute according to directions, and get excellent results.
Posted: Mon Aug 13, 2018 12:23 pm
by SteveHGraham
So far, I have only used the Roundup brand, so I don't know what else is out there. I don't know how strong it is. The expensive version seems to work fairly well. The cheap one might as well be water. It's good for killing plants you want to keep, however.
Posted: Mon Aug 13, 2018 12:29 pm
by BadDog
Note the dilution. I'm guessing the "cheap version" is the low percentage variety? But then the only difference should be further dilution to prepare for spray. I've recently switch to the generic 41% (IIRC) 2 gallon jug that's cheaper than the 1 gal Roundup of the same dilution. Haven't used it yet, so we'll see. I also use "ground clear" (a 1 year pre-emergent) along drives, drainage "stream beds", and anywhere well away (and beyond root zones) from anything I actually want to live. Very different application methods, but works well for me.
Posted: Mon Aug 13, 2018 12:45 pm
by SteveHGraham
Here is my groundless theory: whatever the expensive version's concentration is, I'll bet it contains a surfactant. Poison ivy is oily, so it maybe that Roundup rolls off unless it has detergent in it.
Posted: Mon Aug 13, 2018 3:38 pm
by liveaboard
I have a tenant who works for Monsanto; he pointed out to me the importance of the "co-compounds" in pesticides and herbicides.
Yes, the surfactant or whatever gets it into the target plant. the good stuff is in the expensive brands.
Posted: Mon Aug 13, 2018 4:18 pm
by John Hasler
There's nothing magic about surfactants. If you wish you can add something such as this
https://www.domyown.com/nonionic-surfac ... -1771.html to Kill-Zall. The "good stuff" in the expensive brands is marketing.
Posted: Mon Aug 13, 2018 8:52 pm
by Russ Hanscom
We have been using the generic brands for some time with no change in results. Just observe the concentration on the container and mix accordingly. Saves a bunch of money.
Posted: Sat Aug 18, 2018 7:20 pm
by Richard_W
SteveHGraham wrote: ↑Thu Aug 02, 2018 9:17 pm
Stump grinders cost money!
So do tractors and trucks. I seen a new kabota with a broken differential my neighbor bought. Rent a stump grinder. Use the right tool for the job. Better yet buy the right tool. You can make money on the side.
Posted: Sat Aug 18, 2018 7:49 pm
by John Hasler
Richard_W wrote: ↑Sat Aug 18, 2018 7:20 pm
How did he manage to break the differential on a tractor?
Posted: Sat Aug 18, 2018 8:23 pm
by NP317
Stump pulling, no doubt.
Posted: Sat Aug 18, 2018 9:52 pm
by John Hasler
NP317 wrote: ↑Sat Aug 18, 2018 8:23 pm
Pulling is what tractors are *for*.
