What is This Thing?
Moderators: Harold_V, websterz
SteveHGraham
What is This Thing?
Post by SteveHGraham » Tue Oct 16, 2018 5:47 pm
I have two of these in my yard, right next to each other. I thought they were manifolds for the pool. Wild guess. Now I'm not so sure. Any clues? Mine have pressure gauges on them.
SteveHGraham
Re: What is This Thing?
Post by SteveHGraham » Tue Oct 16, 2018 5:57 pm
I think it may be an "indexing valve."
Post by Harold_V » Wed Oct 17, 2018 2:02 am
Time bomb.
tornitore45
Post by tornitore45 » Wed Oct 17, 2018 4:45 am
The cap has a bail latch. It may be easy to open and seeing the inside may give you a clue of what it does. Not necessarily what is the purpose.
Mauro Gaetano
in Austin TX
curtis cutter
Post by curtis cutter » Wed Oct 17, 2018 8:38 am
Before you pull the cap off to investigate I would recommend throwing the breaker to any septic pumps you may have. :) Just a thought.
Gregg
ctwo
Post by ctwo » Wed Oct 17, 2018 10:55 am
It kinda looks like some automatic sprinkler valves I've seen, or the anti-backflow valve part of it...
SteveHGraham
Post by SteveHGraham » Wed Oct 17, 2018 12:31 pm
I have never heard of septic pumps. Sounds horrible
It appears that this thing is an indexing valve, which is a primitive and unreliable tool for shifting between zones when using sprinklers.
spro
Post by spro » Wed Oct 17, 2018 4:07 pm
Anyway. It is a thing which you don't want to take head off just now. Plenty of water now but who knows about next year's drought. Stick a little wire flag pole next to it, so don't mow it down.
John Hasler
Post by John Hasler » Wed Oct 17, 2018 6:16 pm
in Wisconsin we have something called the "Wisconsin Mound System". It's what you must use if your soil is judged inappropriate for a conventional drain field. Basically, they build a mound of sand and gravel and install the drain field in it so that it is above grade. They then install a timer-controlled pump to lift liquid from the buried tank up to the drain field.
This is, of course, much more profitable to the plumbers. The plumbers also do the perk test to determine whether or not you need one.
SteveHGraham
Post by SteveHGraham » Wed Oct 17, 2018 6:41 pm
Rather poop in a bucket.
GlennW
Post by GlennW » Thu Oct 18, 2018 8:03 pm
I knew them as Fimco Valves back when I was in High School, named after the manufacturer.
Every time the pump cycled off and back on it would change sprinkler stations.
It didn't take much to make them stick on one station...
