Lathe setup device
Mr Ron
Lathe setup device
Post by Mr Ron » Mon Jul 01, 2019 3:35 pm
I came up with an idea that could help in setting up cutting tool bits to the lathe center. It would use a laser. Has anyone made such a device or has one been marketed?
Mr.Ron from South Mississippi
Top
Re: Lathe setup device
Post by Bill Shields » Sun Jul 07, 2019 7:42 am
There are laser measuring tools already on the commercial market. (hold wallet)
https://www.blum-novotest.com/us/produk ... ntrol.html
they are most commonly seen on milling machines, but apply to lathes as well.
easylaser.com is another one that comes to mind
earlgo
Post by earlgo » Sun Jul 07, 2019 8:21 am
This method is far less expensive.
In this pic the fish tail scale is tipped because the tool is above center.
scale tipped
In this pic the fish tail scale is vertical because the tool in on center.
scale vertical
Just my method.
--earlgo
Post by John Hasler » Sun Jul 07, 2019 10:09 am
Top
Google lathe laser alignment. Lots of very expensive industrial products but also lots of DIY articles using inexpensive laser modules.
BigDumbDinosaur
Post by BigDumbDinosaur » Sun Jul 07, 2019 2:06 pm
Looks expensive. :shock:
Post by Bill Shields » Sun Jul 07, 2019 2:11 pm
you have no idea...measures tools, while spinning....to values well below the resolution of the machine motion
Post by SteveM » Mon Jul 08, 2019 2:12 pm
I think that most of the lasers that we civilians have access to have too wide a beam to be used for something this precise.
I use Earlgo's method. It definitely gets me to better than the width of the typical laser I can afford.
I once tried to use a carpentry laser to do a wheel alignment and found that it was nowhere near as accurate as sighting thru the tube on the alignment tool. Perfectly suitable for its intended use - lining 2x4's.
curtis cutter
Post by curtis cutter » Mon Jul 08, 2019 5:25 pm
I made a device that uses a light to indicate on center.
I sandwiched a very thin piece of sheet metal between two plastic inserts and stacked them on a steel column with a bolt to hold the whole stack together. I then ran a wire from the base of the device to the thin piece of metal with a 9v battery and an indicator light in series.
Once the tool contacted the thin metal the circuit was closed and the light came on.
To verify the accuracy each time I used it, I got out the fish tail or feeler gauge.
Now I skip the light and go right to the fish tail. :)
Gregg
Post by John Hasler » Mon Jul 08, 2019 9:53 pm
You need to add a pinhole collimator to get a small spot size. It's not hard to do.
