Trailer Plans Source?
Any one know of a source of plans for trailers? I am looking for one in the 5 x 8 to 5 x 10 range with a 2000 lbs. capacity. Thanks.
Re: Trailer Plans Source?
Northern Tool (it may be Northern Tool and Equipment, the catalog is at work) has various plans and quite a bit of trailer parts listed in their catalog. Mike
George,
There's a chapter in Haynes "Welding Manual" that shows how to build a utility trailer. The book is available from Sears for about $20 and half that price from HF. Your local auto parts store might carry the Haynes books. Good luck.
len
len
Built my last utility trailer from a Dodge carryvan Rear Axel. The whole thing with springs, hangers shocks, and tires just un bolts and makes a dandy Axel setup. Got mine at a wreching yard for $20 clams. Some Iron of your choice and your pulling. Not much to figure just used the existing spring hangers and go. The next one I build I am going to split the Axel and make a wide one. Fenders can be obtained from a boat supply or marina and are eazy to weld on.
George,
Awhile back I was looking for plans for a hydraulic dump trailer and stumbled upon this site. http://www.trailerplans.org/ I just ordered the materials for my dumper today and hopefully things will come together in the next week or two.
Enjoy
Enjoy
Bruce Mowbray
Springville & Southern RR
look at these:
http://www.etrailerpart.com/
http://www.utilitytrailerkit.com/mywebs ... oducts.htm
http://www.synthx.com/btw/trailers.htm
http://www.tufindustries.com/trailerplans.htm
http://www.elamtrailers.com/plans.htm
http://cad-designplus.com/trailer-plans/
If it works Don't fix it....
George. someone has a set (15 Plans ) on Ebay now. Goes off in less than24 hrs. Check that out Under "Shop Essentials"
