shop crane/shrub puller
Converted engine cherry picker so I could lift mill head high enough to bolt up.
Moved to new home with 8' gagage ceiling. Boat winch allows me to snub load
tightly to boom and lift higher. Pulls shrubs too,,,,,,,
Charles Shearon
illigitimi carborundumis
- Site Admin
Re: shop crane/shrub puller
Rats, something happened to the picture. Did you give it enough time to upload or was it larger than 100K?
Marty
Marty
I didn't get it either, and I sure wanted some advice on pulling shrubs....
BP 2j vs, SB lathe, W& S #4 Turret lathe, Maho 600P
Well, at lest some of the roof comes in clear.
Re: shrub puller
wrap a chain around the shrub and wrap the other end around a frame member of your 4x4 and idle away. Works great if the ground is damp.
Charles Shearon
Re: shrub puller
George, it will even work better if you have a large wheel to stand up next to the shrub, or post you may be pulling out of the ground, and run the chain up and over the wheel and down to the bottom of post or shrub and then pull away. This exerts pressure up, the same as the cherry picker instead of sideways. I use an aluminum 24" semi truck wheel. These wheels crack pretty often and it is illiegal to repair them so they aren't too hard to get ahold of.
Michael
Michael
Saimp 2 HP 10 X 44 mill, #2 Cin Horz Mill, Cholchester 13" lathe, LeBlond 15" Dual Drive.
might-A known U. live in have a nice DAY limp wristed CALIFORNIA .
DOWN HOME ( read ) KY. wee wood-A had job done before U. found your chain.
receipe 1/4 stick 80% -- 1 cap. --1 battery. stump gone mill head lifted . time 4 breakfest. just good- ole- boy,s haven fun. y,all come back now ya. hear
Too much trouble to cut it to a quarter stick, just use the whole stick adn run a little faster towards the breakfast table. David from Jax
is U. krazy don't waste . might need this fall. when them city boy,s come a nosing
thru the woods a looking 2 steal a mans hard earnd crop. . that,s NOT taken kindly round here. tresspassers will b. shot surrviors will b shot again
