plastic door things or whatever they are called
I have seen long strips of clear plastic used on trailer doors to keep heat in. These strip completly covered the door opening. They were 8-13 inches wide and went from the top of the door to the bottom of the door. What is this stuff and where can I get it. As I remember it was pretty thick and heavy enough that it did not blow around easily. I have seen it both on the walk in door and the rear doors of trailers. Does anyone know what I am talking about???
Re: plastic door things or whatever they are called
Uou eather want, Garage door weather strip, or the clear PVC 8" to 10" wide. Strip is at any good garage door store and the PVC material is in McMASTER CARR.
Check out mscdirect.com then look up "vinyl strip door kits" you should find everything you are looking for
A company called <A HREF="http://www.curtronproducts.com/">Curtron</A> makes door kits which include door strips with the ends folded over into loops, a rod which fits through the loops and some fairly low grade but functional mounting hardware. They make various grades for different purposes (freezer doors, exterior doors, etc.). I found them at a restaurant supply store.
I have them on my shop door going into the garage. They really work good. Hold the heat and the A/C in. Hnag them back when not in use.
I got mine from a rubber supply store in strips. You may ask if they have any short pieces of rolls. Don't recall what they cost anymore.
Mine came from General Rubber Supply- Louisville, KY
Tek Supply has themprice between 30- .70 cents per foot1-800-835-7877
David
David
