The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Thu May 23, 2013 8:50 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: Pipe Help Pleeeeeze
PostPosted: Sun Jan 01, 2012 2:53 pm
Offline
rudd wrote:
http://www.fernco.com/
Yep that is what I was talking about.
Just wrap the pipe with Rubber tape. and put the 2" coupling over it.
JIm
_________________
Armed Men are Citizens, Unarmed men are Subjects.
Top
 Profile
PostPosted: Mon Jan 09, 2012 3:55 pm
Offline
UPDATE;
Here was my fix. No hub sleeve would have left a ledge in the fitting junction. Not a good thing in a drain line to catch lint, soap,and crud in general.
Drilled out the old lead joint and pried remainder of lead and oakem out with screwdriver. Plumbing World for a Rubber Hub Adapter that is a very snug fit into old cast iron joint collar. Short 1 1/2" ABS trap adapter to that and everything is downhill as meant to be.
Thanx guys
Top
 Profile
PostPosted: Tue Jan 10, 2012 6:02 pm
Offline
No, Kudos to you in finding the working solution. Always more than one way to skin a Womp rat, eh? :D
_________________
Big Dave
Be Alert! The world needs more Lerts.
Top
 Profile
PostPosted: Fri Apr 13, 2012 8:42 pm
Offline
Now that I've inherited Dads "home plumbing solutions" I can honestly say that I am basically a master plumber :mrgreen:
He hung pipes with wire and rope, in 25 units.
Used silicone (for windows and doors" to seal oakum and lead joints.
ALL his traps are 1.25 and chrome plated into WHATEVER he could reach.
Often it takes me numerous times to the Lowe's.
I understand that he "made it work"; But recently I had a leak behind the 3rd floor which ruined the 2nd floor, I am 30 minutes away. Turned out dad felt blocking off the extra 1/2" NPT made from brass, he would use steel. It rotted and I bet would have blew out the next day. Oh yes, and when I got all done, some of that steel contamination plugged the toilet supply float so I cleared it and put in a fluid master.
Thanks Dad :roll:
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
