I need to move my 330 gallon home heating oil tank across the basement. The move is about 30 feet.
Right now, there's 150 gallons of oil, so we're looking at 900 pounds of oil and a 300 pound tank. Me and 20 of my closest friends could pick it up and move it, but since I don't have that many friends, we're going to have to use brains and not brawn on this one.
I don't have a dolly big enough, nor casters strong enough for that kind of load, although I could move my 40"x48" trailer into the basement and maybe use that, but I digress.
Moving it full is probably not worth the risk to life, limb and risking the possible oil spill.
The tank is a standard 330 gallon "upright" tank, which means that it's not upright, but just laying down on the smaller side instead of being on the flat side. It would be nice if they could stand them up on end and have them take up less space - I mean, there's seven feet of ceiling height, why not use it?
Options seem to be:
pump the oil into three 55-gallon drums
move the tank
pump the oil from the 55-gallon drums back into the tank
Drums can be had for $30-$50 each and I can sell them when I'm done and get most of my money back.
Buy a new 330 gallon tank
install in the new location
pump from the old tank to the new tank
Advantage - I get a new tank (the old one's about 30 years old, but it's still solid)
Disadvantage - tank costs about $500.
In either case, I need a pump.
I thought about this one:
http://www.surpluscenter.com/item.asp?i ... 6&catname=but it says "not for flammable liquids" although it says it can be used for waste oil. Guess it's just a question as to what point is it flammable (or as George Carlin would have said "either it flams or it doesn't").
Also, they sell catch pans to go under the tank and as long as I'm moving it, now would be a good time to spring for one of those.
Any suggestions for pumps and comments/suggestions on the move?
