Picture test
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
Marty_Escarcega
Site Admin
Picture test
Post by Marty_Escarcega » Thu Nov 03, 2016 6:54 pm
BigDumbDinosaur
Re: Picture test
Post by BigDumbDinosaur » Thu Nov 03, 2016 9:00 pm
Marty_Escarcega wrote:VFD enclosure with VFD mounted no wiring small.jpg
What was the size of the file from which you uploaded? PHP-BB seems to be truncating the file itself during the upload.
Re: Picture test
Post by spro » Fri Nov 04, 2016 5:21 am
I appreciate the improvements to the Board. This definition issue may well be to software, don't know. I'm a dumber dinosaur. I'm sure many tests included sending your file out and back to you. Something has been occurring with the Net.
Reason: To remove political content
Re: Picture test
Post by GlennW » Fri Nov 04, 2016 7:58 am
originally 5152 x 3864
Could it be Browser related?
I'm using Chrome and anything and everything I've tried seems to work.
BigDumbDinosaur
Re: Picture test
Post by BigDumbDinosaur » Fri Nov 04, 2016 9:16 am
GlennW wrote:DSC00023.JPG
Using Seamonkey, but have also tested on Internet Exploder. The key seems to be in the file size (not the image size) being truncated. What is the size of the file that you uploaded?
Re: Picture test
Post by GlennW » Fri Nov 04, 2016 9:54 am
7.1 mb
Re: Picture test
Post by SteveHGraham » Fri Nov 04, 2016 10:53 am
Using a lathe to make a hole in an exhaust flange?
Re: Picture test
Post by GlennW » Fri Nov 04, 2016 1:46 pm
Yes, the other three holes are done from the top in the mill, but that one hole is obscured by the pipe and needs to be done from the bottom.
The holes were just being enlarged to fit over larger studs.
Flood cutting oil and carriage feed wasn't so bad either with stainless.
BigDumbDinosaur
Re: Picture test
Post by BigDumbDinosaur » Fri Nov 04, 2016 5:26 pm
SteveHGraham wrote:Using a lathe to make a hole in an exhaust flange?
Borrowing and corrupting your tagline, if your only tool is a lathe, everything is a turning job. :lol:
BigDumbDinosaur
Re: Picture test
Post by BigDumbDinosaur » Fri Nov 04, 2016 5:28 pm
GlennW wrote:7.1 mb
Interesting. Did you reduce it in any way before uploading?
Re: Picture test
Post by SteveHGraham » Fri Nov 04, 2016 6:57 pm
I knew Glenn was not short on tools, so I wondered what was up.
Re: Picture test
Post by GlennW » Fri Nov 04, 2016 8:07 pm
BigDumbDinosaur wrote:
GlennW wrote:7.1 mb
No, I didn't do anything. Just pointed to it and it uploaded and worked as usual.
Here's a 1.3 mb, so size doesn't seem to affect it.
This is from home, which is running Chrome as well, though. The other was from my computer at work.
