Unable to edit notifications
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
LVRR2095
Post by LVRR2095 » Wed Feb 01, 2017 2:29 pm
I have been trying to edit the way I am contacted about notifications unsuccessfully.
I un-click those areas where I only wish to be notified by e-mail. I click "submit" a screen appears that says my preferences have been updated, and when I return to the preferences page, it has gone back to the default and NOT what I selected.
What am I doing wrong?
Keith Taylor
Re: Unable to edit notifications
Post by Harold_V » Wed Feb 01, 2017 4:42 pm
Keith,
I attempted to edit mine and found the same problem. I'll report this issue to Mike.
LVRR2095
Post by LVRR2095 » Wed Feb 01, 2017 6:50 pm
Harold_V wrote:Keith,
Thanks!
Keith
dorin
Post by dorin » Thu Feb 02, 2017 3:23 pm
Interestingly enough I was able to reproduce it, but then I was successful.
Suggest trying this.
As you did before:
* go to User Control Panel->Edit Notification Options.
* Select the notifications you want deleted.
* hit submit
When you see the screen that your preferences have been updated...wait a moment...don't press any buttons.
Your screen should update itself and the notifications might be correct!
Please try and let me know.
-Mike
www.chaski.com
LVRR2095
Post by LVRR2095 » Thu Feb 02, 2017 4:40 pm
I did as you suggested and when the page updated....it went right back to the pre-change selections it did not update.
Keith
dorin
Post by dorin » Fri Feb 03, 2017 11:21 am
I am still investigating...
-Mike
www.chaski.com
Post by Harold_V » Fri Feb 03, 2017 3:16 pm
I have toyed with the issue and discovered that you can edit such that you can receive email notifications, or not, but the notifications that appear on the board default back to the board settings. Unless there is a change in the software, editing that portion (the first column, assuming one is using subsilver2) is not possible.
