New user anti spambot questions
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
RLWP
Post by RLWP »
Is it deliberate that the only way to answer the mathematical question is to put in the wrong answer?
Richard
GlennW
Re: New user anti spambot questions
Post by GlennW »
Wow, finally, a test I could pass!
Where is it? :)
dorin
Post by dorin »
Really, shoot! I didn't mean that.
What were you seeing? I seems it is setup correctly...on the other hand..what a way to mess up the spambots!
www.chaski.com
RLWP
Post by RLWP »
If you do the sum and put in the answer, the page rejects it saying it is wrong, and the number must be bigger than another number - which is actually the answer!
:shock:
Richard
dorin
Post by dorin »
I must be missing something, sorry.
Here is the problem:
"To discourage spambots, please solve the following math problem. What is 4 + 5?"
Default is 0 so it has to be answer.
If I hit submit I get:
The field “antispam” must be completed.
The value of “antispam problem” is too small, a minimum value of 9 is required.
I put 9 and the only warning is for the other field...
I think that is working right...I must be missing something.
www.chaski.com
RLWP
Post by RLWP »
Don't worry, I must be going nuts. I was sure it asked what's 3+5...
Anyway, I still got through the process, so all is well
Richard
