Is it deliberate that the only way to answer the mathematical question is to put in the wrong answer?
Richard
New user anti spambot questions
Moderators: Harold_V, Marty_Escarcega
Re: New user anti spambot questions
Wow, finally, a test I could pass!
Where is it?
Where is it?
Really, shoot! I didn't mean that.
What were you seeing? I seems it is setup correctly...on the other hand..what a way to mess up the spambots!
www.chaski.com
If you do the sum and put in the answer, the page rejects it saying it is wrong, and the number must be bigger than another number - which is actually the answer!
Richard
Richard
I must be missing something, sorry.
Here is the problem:
"To discourage spambots, please solve the following math problem. What is 4 + 5?"
Default is 0 so it has to be answer.
If I hit submit I get:
The field “antispam” must be completed.
The value of “antispam problem” is too small, a minimum value of 9 is required.
I put 9 and the only warning is for the other field...
I think that is working right...I must be missing something.
www.chaski.com
Don't worry, I must be going nuts. I was sure it asked what's 3+5...
Anyway, I still got through the process, so all is well
Richard
Richard
