Page 3 of 6
Re: Thinking of posting pictures?
Posted: Sun Oct 25, 2015 3:42 pm
by Harold_V
Bruce wrote:I can't upload a picture. I do not have a "browse" button, only one which reads: Choose File. when I click that, I get to browse my files. I choose a photo that I've have downsized to 800 X 800 and after the downloading-in-progress window disappearsI get a message that the photo is something like 24xxx X 22xxx and too large.
Bruce
That's interesting. I have to wonder if, maybe, the picture hasn't been resized and properly saved accordingly. One thing that concerns me is that you suggest it has been altered to 800 x 800 pixels. While that's not impossible, it is a rather unusual pixel count, and is reflected by the fact that the message you receive suggests a size of 24XX x 22XX. As stated, anything larger than 1024 X 1024 is rejected.
I will report this issue to administration, but in the mean time, would you please try posting a different picture, one that you know to be of acceptable size? Post it to this thread, responding to this message.
Thanks,
Posted: Wed Nov 04, 2015 6:54 pm
by billboat10
test run
Posted: Tue Dec 01, 2015 12:33 am
by optigman
Harold_V wrote:
db133 wrote:I know how to resize a picture !
How do I post one ? There are no details on how to do it !
Real easy, made even easier if you'll go to the page where you reply to a post, so you can see what I'm talking about. You can do that and have these instructions to read by clicking on the Quote button at the bottom right of this post. I'm assuming you're using the default board choice, subsilver2.
After composing your post, look below the box in which you entered text. You'll see a broad blue line with orange text within. The line says Upload attachment. Pictures can be posted two ways on this board. One of them is to host the picture on the Chaski server, which is what this method will do for you.
Below the blue line, you'll see a box, within which it says Browse. That permits you to access your pictures, where you have them stored on your computer. Go there and select the picture you wish to post. Follow the instructions that appear. Once selected, click the button below the Browse button, which says Add the file. Allow time for the picture to be uploaded. Done. If you wish to post more than one, simply repeat. Note that there is a limit on how many pictures you can add to each post, and that's partially determined by the file size of the pictures. Posts are limited in size, but they are more large enough for even the most windy of individuals. They can be overwhelmed by pictures, however, so use good sense.
If you store your pictures off your own computer, all you need do is provide a link to the picture you wish to post. No special brackets or coding required---just post the link.
Ask for more guidance if you're still confused.
Posted: Tue Dec 01, 2015 9:59 am
by Bruce
Thanks Harold.
Posted: Tue Feb 02, 2016 2:24 am
by battleboy
Test
Posted: Wed Oct 19, 2016 3:02 pm
by Erskine Tramway
How do I post a picture in my post using the new "Img" button? It apparently doesn't work the same way as the old "attachments" button. It's asking for something in between the two "" sections, and I don't know what it is, or where to find it.
Thanks,
Mike
Posted: Wed Oct 19, 2016 3:12 pm
by Harold_V
Erskine Tramway wrote:How do I post a picture in my post using the new "Img" button? It apparently doesn't work the same way as the old "attachments" button. It's asking for something in between the two "" sections, and I don't know what it is, or where to find it.
Thanks,
Mike
Assuming you host your images on the Chaski board when posting, one does not use the Img button. Instead, drop down below the heavy blue line (I'm assuming you use subsilver2 as your board choice, as I do) and attach your images as attachments. This is the most reliable method of including images, as they remain with the board under normal circumstances. Hosting them elsewhere offers a greater risk of getting lost.
Posted: Mon Oct 24, 2016 12:09 pm
by Erskine Tramway
Thank you, Harold.....
I see it now.
Mike
Posted: Mon Oct 24, 2016 4:37 pm
by BigDumbDinosaur
Also note that there is an intermittent issue with posting graphics interchange format (GIF) files that is presently being debugged. GIFs are better for posting on BBSes such as this one, as the files are generally more compact than other image types, helping to conserve server disk space.
Posted: Sat Nov 05, 2016 3:01 pm
by larry_g
test mill pict
Photo test of mill..
lg
no neat sig line
Posted: Mon Dec 26, 2016 4:51 pm
by oscar g
By oscar g .Changing a fixed handle to a recessed position, on my mill.
Posted: Mon Dec 26, 2016 5:00 pm
by oscar g
