BCA Jig Borer
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
Sandiapaul
BCA Jig Borer
Post by Sandiapaul » Sat Aug 17, 2019 4:03 pm
I'm selling my BCA jig borer. It was a longtime goal of mine to own one of these rarely seen in the US machines. When one came up I jumped on it a few years ago. Soon after getting it an Aciera F2 came my way and while I'd like to keep the BCA I need the room and want to fund a new project. It is a Mark III machine and unusually it has a rectangular table. Some were made that way by the factory, however this one appears to be a later modification.
The machine came with the factory base, but I put the machine on a bench, the base has a couple of dings in the sheet metal as seen in the pics. The base is included in the price.
I added a new 120 V motor and a vari speed control which works well. The original motor is available if you want it, I also have the original switch which I removed. I sourced a nice rotary table for it too. That is also available separately. Table is good quality, made in Japan. The table has a couple of "oops" marks in it(not made by me!) Collets and drill chuck are included of course.
I also have a Pultra 10mm headstock and an unknown tailstock I was going to use to make a setup to hold parts to do indexing. This will require significant work to make, but its a start anyway.
You will need to pick this up in central NJ near Princeton.
BCA jig borer with collets, drill ckuck, low profile vise and original base: $1850.00
6" rotary table: $250.00
Head and tailstock to use as a DIY indexer: $100.00
Much more about the BCA is here:
http://www.lathes.co.uk/bca/
Contact me at
loco lima @gmail.com remove spaces
high res pics are here:
https://www.flickr.com/photos/20941728@ ... 0375427552
spro
Re: BCA Jig Borer
Post by spro » Fri Aug 30, 2019 1:41 pm
That is a sweet rare machine. I hope you get some bites and bytes from someone.
Sandiapaul
Re: BCA Jig Borer
Post by Sandiapaul » Sun Sep 01, 2019 7:06 am
spro, so do I but none yet!
Sandiapaul
Re: BCA Jig Borer
Post by Sandiapaul » Sun Sep 01, 2019 9:45 am
Labor Day special!
Machine $1650.00
Rotary Table:$200
Head and tailstock: $50.00
Sandiapaul
Re: BCA Jig Borer
Post by Sandiapaul » Sat Sep 07, 2019 7:10 am
Want to move this guy out, $1550.00 for all.
