Needed - Atlas 12" Lathe Tailstock Quill / Ram / Barrel / Spindle
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
rsterne
Post by rsterne »
Whatever you want to call is, mine is stripped!.... The Acme threaded screw that drives it by the handwheel is fine, but the female threads in the ram are shot....
If you have one, or know where I can get one, please let me know.... :roll:
Bob
Re: Needed - Atlas 12" Lathe Tailstock Quill / Ram / Barrel / Spindle
You can purchase a bronze nut, bore the old one out of the quill and fit the new nut with loctite into the quill.
Been there done that on another lathe ->
rsterne
Post by rsterne »
Good idea, I don't know where to get a bronze nut, but probably easier to find than a quill.... I have some Loctite 638 bearing mount here, that should work!....
Bob
McMaster carr
Maybe not bronze
rsterne
Post by rsterne »
Won't sell to Canada, but I have a friend in the US that could get it and send it to me.... Many thanks.... Is there any advantage to bronze over steel?....
Bob
Probably not, just preference for these applications...look at all the feed screw systems on lathes...most are bronze on steel
Look on Google search.
If one nut is not thick enough, you can gang them up, screw them on the male thread and loctite in place .
Be creative
rsterne
Post by rsterne »
Thanks again....
Bob
It's usually a good idea to avoid running steel on steel, which tends to lead to galling. If you can't find the appropriate nut made of bronze, don't hesitate to buy one made of gray iron (or even better, ductile iron) if possible. Iron on steel is a very acceptable bearing.
rsterne
Post by rsterne »
I have found a acme 1/2"-10 LH nut in brass with flange, and the body is 3/4" OD, which I can fit into the quill.... The body is 3/4" long, and the flange is 1/4", but I would turn that off to end up with a 1" long nut.... My question is if brass is strong enough?....
The company want a ridiculous price to send to Canada, $53 for a $5 part by UPS !.... I may see if I can get an American friend to get it and mail it to me....
Bob
Is ok ..bronze would be better.
Purchase a bunch of nuts at that shipping price.
What is your postal address in CA?
rsterne
Post by rsterne »
I have a couple of the flanged brass nuts coming, they reduced the shipping to $20.... ZYLtech is a wonderful company to deal with....
Thanks to all of you for your help, it is VERY much appreciated.... 8)
Bob
Now you need to get the lead screw out of the tail body. Usually you take off the handle...giggle...
