FS: Craftsman Atlas Covel Power Hacksaw parts
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
crrmeyer
Post by crrmeyer » Thu Dec 28, 2017 12:45 pm
These parts came off of a Craftsman 108.1501 hacksaw like in the photo below. These parts should also fit the Atlas Covel 4350 power hack saw. Prices do not include shipping. I usually use USPS Priority Mail flat rate boxes when it is the cheapest option. US sales only.
Link to Atlas Covel 4350 hacksaw manual (the Craftsman manual exploded diagram is hard to read). See parts exploded diagram on Page 5.
http://campkahler.com/files/Atlas-Covel ... Manual.pdf
A) Sliding jaw + clamp assembly, Includes parts 14) 562-153 Pin, (59) 431-016 Sliding jaw, (60) 431-017 Swivel jaw, (65) 562-152 Pin, (66) 445-002 Bottom Knuckle, (67) 057-015 Ball (2 req), (68) 381-063 Handle, (69) 696-229 Vise Screw, (71) 445-001 Swivel Vise Knuckle, & (72) 712-009 Swivel Shoe. For some reason these seem to be missing on a lot of saws and replacements are unavailable from Sears, etc. The swivel vise knuckel looks to have been previously repaired. $38
B) Feed Ratchet block with screws/washers (#3, #4 & #5 in the Covel manual exploded diagram on Page 5) $30
C and Q): Stationary vise jaw with nut and stud (#61 in the Covel manual exploded diagram on Page 5). For some reason the previous owner added a C-Clamp to clamp the material down vertically. You could probably grind the welded c-clamp off if you wanted it close to original. Note the two saw cuts in the vise jaw. $11
crrmeyer
Re: FS: Craftsman Atlas Covel Power Hacksaw parts
Post by crrmeyer » Thu Dec 28, 2017 12:46 pm
D) Arm raising mechanism. Consists of (6) 452-056 Raising Lever - Rear, (7) 556-289 Raising Lever Plate (2 req), (8) 100749 *Screw, Rd Hd, #8-32x1/4 (4 req), (9) 542-055 Raising Lever - Front, (10) 452-058 Main Raising Lever. (11) 642-023 Lifting Arm Roller, (12) 562-150 Roller Pin and (14) 562-153 Pin. Roller moves smoothly. I suspect the Raising Lever Plates may need to be resharpened. $20
E) Blade tensioner and pin holder assembly. Consists of (42) 456384 *Roll Pin. 1/8x3/4, (45) 456876 *Roll Pin. 1/8x1/2, (47) 4350-10 Pin and Holder Assembly, (50) 452-059 Tension Lever, (51) 53-1014 *Thumb Screw, 5/16-18x1-1/4 and (52) 100111 *Screw, Hex Hd, 1/4-20x1-1/4. $15
F: Arm weight. Consists of (40) 946-001 Weight and (41) 113862 *Screw, Rd Hd, 5/16-18x7/8 (2 req) $15
G: Main slide assembly, Consists of (42) 456384 *Roll Pin. 1/8x3/4, (44) 4350-11 Pin and Holder Assembly, (45) 456876 *Roll Pin. 1/8x1/2, (53) 345-056 Gib, (54) 102572 *Set Screw, Soc, 1/4-20x5/8 Cup Pt, (55) 547-011 Oiler and (56) 704-059 Main Slide. $25
(H) Crank lever assembly. Consists of (2) 2 547-014 Oiler, (43) 562-151 Crank Pin and (37) 452-057 Crank Lever $15
crrmeyer
Post by crrmeyer » Thu Dec 28, 2017 12:48 pm
(I) Pinion Gear and Shaft Assembly, (31) 4350-13, $11
(J) Main gear assembly. Consists of (24) 341-301 Main Gear, (25) 562-149 ' Pin, (26) 049-150 Drive Gear Bushing, (27) 53-315 *Screw, Flt Hd, 1/4-20LHx1/2, (28) 932-139 Washer, (38) 932-140 Washer and (39) 113954 *Screw, Rd Hd, 1/4-20x3/8, $19
(K) Rear guard (22) 342-102 with screws, $11
(L) Front Guard (23) 342-101 with screws, $15
(M) Drive Pulley (73) 560-166 with set screw, $11
crrmeyer
Post by crrmeyer » Thu Dec 28, 2017 12:50 pm
(N) Lifting Arm (1) 002-077 with oiler, $25
(O) Head assembly. Consists of (19) 387-030 Head with set screws, lifting arm adjustment screws, and bushings as shown. Also includes 4 mounting screws (not shown) $15
(P) Head assembly pivot pins. Consists of (29) 562-148 Drive Gear Pin, (77) 696-228 Adjusting Screw, and (18) 103585 *Taper Pin, #2x1-1/4. $11
Mike Walsh
Post by Mike Walsh » Wed Jan 03, 2018 10:39 am
PM sent
crrmeyer
Post by crrmeyer » Thu Jan 04, 2018 12:10 am
A, B, D and M have been sold. Thanks
