Taps and dies for sale
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
discodan
Post by discodan » Fri Feb 15, 2019 11:27 pm
These taps all look lightly used or unused. They are all 3 tap sets - taper/plug/bottoming.
Greenfield/TRW
7/8-9 NC lightly used $40
3/4-10 NC looks unused $37
5/8-11 NC lightly used or unused $35
1/2-20 NF looks unused $33
Brubaker
9/16-18 NF lightly used $30
Morse
5/16-18 NC lightly used $20
3/8-16 NC lightly used $25
3/8-24 NF unopened $25
Two square pipe thread dies?? Both are 5/8-11 NC
One is Greenfield and looks new in box $7
One is not marked and looks lightly used $5
Prices do not include shipping. I use flat rate USPS boxes.
Re: Taps and dies for sale
Post by Harold_V » Sat Feb 16, 2019 4:54 pm
Might be a good idea to better describe the taps. Are they hand taps, or are they intended to be power driven?
discodan
Post by discodan » Sat Feb 16, 2019 8:44 pm
Harold_v, how do you tell the difference?
Post by Harold_V » Sun Feb 17, 2019 3:01 am
The grind of taps indicates their intended use. Hand taps have straight flutes with no change of angle at the cutting end. They don't direct the chip--it is intended to enter the flute, and be broken by reversal of the tap.
Taps intended to be power driven may look similar, but they have a lead angle at the cutting edge, either positive (generally a spiral flute) or one with negative lead, which deflects the chip in front, or down the hole. The number of flutes isn't a good indicator, as larger taps have multiple flutes, while small power driven taps have only two.
If all your taps appear to be identical, ignoring size, pitch and intended use (bottoming, taper, plug), post a picture of one tap, doesn't really matter which one. That will give readers an idea of the type of taps you have. I make mention because it's not as easy to use power driven taps by hand (hard to start, but they work well enough if you can start them), and hand taps do not respond well at all to being power driven.
Russ Hanscom
Post by Russ Hanscom » Sun Feb 17, 2019 9:10 am
The ones I got previously were all hand taps. I would think, perhaps without just cause, that three tap sets would inherently be hand taps.
discodan
Post by discodan » Sun Feb 17, 2019 9:20 am
Yes, they are all 4 flute hand taps. One if the boxes is open so you can see what they all look like.
discodan
Post by discodan » Mon Feb 18, 2019 11:32 pm
Here is a pic of them out of box except the one Morse set that is sealed in box new. They are in the same order as above pic.
discodan
Post by discodan » Sat Mar 02, 2019 8:17 pm
Feel free to make an offer. Happy to give a bulk discount.
discodan
Post by discodan » Thu Mar 21, 2019 1:53 pm
Make an offer.
