WTB 60T 18DP Aluminum Gear
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
dly31
Post by dly31 » Wed Feb 20, 2019 10:40 pm
Need replacement gear for SB Fourteen lathe speed control. Existing gear is 14.5 PA, 1/4" wide and has a 1" bore. PM or "donandjune #at#att#dot#net".
Don Young
Don Young
Lazz
Location: The Warm Arizona Deserts... Phoenix to be precise...
Re: WTB 60T 18DP Aluminum Gear
Post by Lazz » Thu Feb 21, 2019 8:10 pm
I was going to offer the gear cutting service you want.
And of course after checking the proper cutter can not be found....
If you only wanted a 54 tooth gear... I could do that...
dly31
Post by dly31 » Thu Feb 21, 2019 9:14 pm
Thanks for the offer. I bought a few 18DP 14.5 PA cutters a long time ago. If I can find them and the proper one is included I could furnish it to you. I do not have anything set up to do gear cutting yet. I will be in touch.
Don Young
Lazz
Post by Lazz » Fri Feb 22, 2019 11:02 am
If you have the correct involute gear cutter Ill be glad to cut you a gear...
tetramachine
Post by tetramachine » Fri Feb 22, 2019 5:36 pm
Are you sure you want AL for the gear, Bronze or iron seems more common in that application. I do have a full set of 18dp cutters, Not sure the PA, need to measure the last ones I cut to be sure.
Does the gear have a Hub, Keyway, bushing?
Let me know if you would like me to cut one for you.
You could send me a blank or I can make one .
Tom
My wheels don't slow me down
dly31
Post by dly31 » Sat Mar 16, 2019 10:18 pm
Thanks to tetramachine I have the gear and a couple of spares. Thanks again to Lazz for the offer.
Don Young
